Identifying Oil Leak #4 - Line Behind Oil Filter
Old Sep 16, 2016 | 03:49 PM
MikeofBonsall's Avatar
Default Identifying Oil Leak #4 - Line Behind Oil Filter
Oil Leak #4 from the just acquired 2004 XK8 come from a line I can not identyfy. Line is part hose about 1/2" did and part metal tube that firs inside this hose. It passes directly by and above the top of the oil filter. It is no more than 2 inch from oil filter.
It looks like it has had a fix or a modification because this line is held to the wishbone by a plastic tie. I'll add a picture.
All and any enlightenment gratefully received.
Attached Thumbnails Identifying Oil Leak #4 - Line Behind Oil Filter-leakingline.jpg
Old Sep 17, 2016 | 03:30 PM
plums's Avatar
Since you do not show endpoints, but the starter is showing
the best guess is a power steering line.
You can confirm locally by actually following the line to it's
two endpoints.
Old Sep 17, 2016 | 03:54 PM
Yes I have come to agree with you. Almost impossible to get a hand on it to fix!
brokic
Mar 1, 2017 07:39 AM
MikeofBonsall
Sep 14, 2016 07:12 AM
BradsCat
Sep 13, 2016 06:47 PM
annamiata
Sep 13, 2016 05:36 PM
MikeofBonsall
Sep 11, 2016 09:36 AM
