IDS 131 Scan Errors
Old Nov 10, 2025 | 05:12 PM
CorStevens's Avatar
Default IDS 131 Scan Errors
Receiving the following errors when performing an IDS scan. Everything else scans fine with full access, and I can change settings, etc.
Cannot connect to the body control module. Receiving: [ERR 0x1407] !Serial Communications Error.
Instrument pack [1 DTC] U1261 SCP (J1850)(-) circuit failure. The cluster is apparently working fine.
Thanks.
Old Nov 11, 2025 | 02:41 AM
dibbit's Avatar
If everything is working, then I wouldn't worry about it. Do your trip switches work? Do your seat controls work? Can you lock/unlock the passenger door from the drivers door?
If there aren't any faults then there is nothing to fix.
Old Nov 11, 2025 | 11:51 AM
CorStevens's Avatar
Yes, I agree with you and so does a friend in the hobby. However, two things, was able to access and change settings (climate control) with the same car and IDS installation and using my AutoLogic, etc. more than once. So, something has changed which makes me wonder what else might be about to change. And, there is a setting which I would like to access.
Currently, everything works great, until they do not. Learned the hard way with other machines not to ignore unexplained signs of change...
Arsenal01
General Tech Help
28
Mar 1, 2025 09:22 AM
Sone
Jun 10, 2023 07:18 PM
jugo
Sep 26, 2022 04:47 AM
TheWeirdOne
Dec 16, 2021 02:54 PM
wforslund3
Jul 29, 2020 11:24 AM
