IDS VCM Mongoose adapter for 1997 xk8 which one
Old Jul 13, 2025 | 05:11 PM
daveb97's Avatar
Default IDS VCM Mongoose adapter for 1997 xk8 which one
Hi all, first great forum I have learned alot about my recent acquisition 1997 XK8. I want to get up and running on the SDD/IDS system i have the software and an old laptop, what i really need is which cable should I use i see people talk about Mongoose, VCM
for my car being 1997 I know it will use the IDS software but all the post are confusing on the adapter to go to the car.
should I use the VCM or the Mongoose, also I saw the true mongoose adapters are very expensive.
Any help here would be greatly appreciated and if any one has a adapter for sale i would be interested.
thanks for the help great bunch of people on here
Old Jul 13, 2025 | 07:20 PM
michaelh's Avatar
Ideally the VCM1, which seems to be priced S/H similar to the DrewTech Mongoose at ~$600.
The cheap Mongoose/Mangoose knockoffs are around 1/10th of that and are OK for diagnostics, but I understand that it's a can of worms if you want to do any serious module flashing, etc. I guess it depends on what you want to achieve.
See this recent thread from sanchez - there are some helpful posts from motorcarman and DonB which will guide you:
https://www.jaguarforums.com/forum/x...2/#post2856986
Old Jul 13, 2025 | 09:12 PM
baxtor's Avatar
I had issues with mongoose and eventually got onto a true clone VCM1, have only needed it on odd occasions but it seems to be full function.
There are many pitfalls to purchasing a fully functional VCM unit however, many out there with gutted circuit boards. Check very carefully that they have the full compliment of boards, double decker, double sided from memory.
Old Jul 13, 2025 | 11:10 PM
xalty's Avatar
a knockoff mongoose will do everything you need on an x100.
it can’t reflash aj26/27 ecms but there’s no reason to ever do that.
steve4ltr
General Tech Help
62
Feb 11, 2024 09:23 AM
onewhippedpuppy
Jun 2, 2023 09:43 PM
Stephjac
General Tech Help
Aug 19, 2020 01:50 PM
M. Stojanovic
May 26, 2018 12:19 PM
sayitaintso
Jan 29, 2018 07:04 PM
