Ignition coils
Old May 1, 2023 | 06:43 PM
Rigelprime's Avatar
Default Ignition coils
I had a coolant leak on Bank 1 that has affected the ignition coils on that side. I have decided to replace the ignition coils completely but am not certain whether I have two pin or four pin coils. I don't wish to try to take the top of the motor apart to find out and wonder if there's a simpler way. I drive a '99 XK8 convertible made in the UK.
Old May 2, 2023 | 12:47 AM
Pistnbroke's Avatar
Well its only 6 bolts with a 7mm socket and you can have a look ...leave the cover off until you get the new ones. It highly unlikely that you will need new coils ..probably got oil or water in the plug holes ..blow with compressed air before refitting coils.
The one nearest the front will have 2 or 4 wires to it.
Old May 2, 2023 | 05:41 AM
michaelh's Avatar
^^What he said.
'99 XK8 is the AJ27 engine, hence 4-wire coils.
JockeF
Sep 25, 2022 12:33 AM
Louisiana
Dec 15, 2021 10:51 AM
Jakob morgan
Mar 12, 2020 01:37 AM
AlexJag
Oct 30, 2019 06:16 PM
zmann96
May 3, 2011 04:26 PM
