Ignition Module
Old May 30, 2009 | 08:36 AM
mlewisfwa's Avatar
Default Ignition Module
Received code P1368 Ignition module (2), I have the correct module on order, can anyone tell me which module is (2), driver side or passanger? I know I have a 50/50 chance, but was hoping to get it correct the first time.
Old May 31, 2009 | 06:39 AM
Fjk's Avatar
Fjk
Ignition Module 2 is right (passenger) side.
If you want the wiring diag. for your car, send me a PM with your E-Mail addr.
I will send it. It is a PDF file
Old Mar 18, 2014 | 10:58 AM
HectorBabilonia's Avatar
Question 1997 Jaguar XK8 ignition module question
I am planning to install an engine of a Jaguar XK8 2001 in a car as mentioned above in the title. I need to know if the ignition module of the 1997 cars has to be changed by the 2001 car. Same question for the engine control module.
I am using the existing harness of 1997. I am using also the throttle control body of 1997.
I will appreciate your recommendations.
Old Mar 18, 2014 | 12:53 PM
RJ237's Avatar
Welcome to the forum, Hector. When you have time please visit the new member area and introduce yourself.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
You are taking on a big project swapping the AJ27 engine for the AJ26. There are several threads covering the swap, just use the search engine to find them.
To ask specific questions relating to problems it would be better if you open a new thread.
hoodun
Nov 20, 2022 02:35 PM
goges
Oct 5, 2015 04:53 PM
leep123
Sep 30, 2015 03:41 PM
zdrapec
Sep 25, 2015 05:49 AM
