Immobilizer ring built into key switch?
Old Jul 10, 2017 | 07:56 AM
cdre's Avatar
Default Immobilizer ring built into key switch?
Digging around to try to figure out if the XK8 immobilizer ring is built into the key switch itself. Can't find anything else on the diagram that looks like a coil, so thinking that's the case. Can tear down the steering column but I've never done that on a car without breaking some random plastic tab that results in rattles... Can anyone confirm?
https://www.potamkinparts.com/oem-pa...bC12OC1nYXM%3D
Old Jul 10, 2017 | 09:25 AM
cdre's Avatar
Wondering if the coil is inside of this:
1998-2002 JAGUAR XJ8/XK8 IGNITION SWITCH | eBay
Old Jul 10, 2017 | 09:31 AM
Richxk8's Avatar
The coil is a separate part, all you need to do is remove the shroud around the ignition switch to access it. I replaced mine about a year ago while trouble shooting a no start issue, wasn't the cause.
Old Jul 10, 2017 | 09:52 AM
DevonDavid's Avatar
If you search on :
Jaguar LJA2668AB - you will get lots of pictures, information etc.
Old Jul 10, 2017 | 10:01 AM
cdre's Avatar
Perfect. Thanks!
