inertia switch 2005-2006 owners please advise
Old Mar 28, 2011 | 01:49 PM
cohibarandy's Avatar
Thanks Gus.... I have the highest respect for your mechanical prowess.
But, on my '05..... They must have moved it. Since it was so close toward the end of the production of that model , jaguar or ford, just decided not to include this update their drawings (Including DHB). Hey,I work at Boeing, and I see this kind of thing all the time(not with the Airpalnes) on many things.
Old Mar 28, 2011 | 04:03 PM
XK8+XJ8L's Avatar
Question Cohibarandy's Right
OK guys - Y'all got me to make a run out to the parking lot with my cellphone/camera, and here are the results:
On my 2006 XK8 (not R), there's just a big, open space next to the fuse block on the driver's (left) side.
Went and checked the passenger side, and there's a black, boxy thingy over there, but it does not have a reset button that I could find, so I'm not sure what it is:
Them's the facts.
Hey cohibarandy - where do you work at Boeing? I'm up in Evt. By the way, you probably never worked on a 707 or 727 that had been in service for years, but lots of times things were not always where the drawings said they were.
Cheers,
Old Mar 28, 2011 | 04:16 PM
Gus's Avatar
Gus
It obviously is not at the fuse box but I would bet it is behind the kick plate. Pull that cover off and see if you do not have a plate as indicated in my last post. Pull it off and I bet it is behind that plate. I worked on aircraft for 4 years and designed 2 tool applications for c141 & ac130 because the engineers / designers put the items in the wrong place. I do understand.
Old Mar 28, 2011 | 04:28 PM
Mountaincat's Avatar
I have a 06' XKR and found the inertia sw. right where the owners manual says it is. Here's the quote from my owners manual "The inertia switch is located behind the trim on the left-hand side (drivers side) of the vehicle, forward of the door post below the fascia. The reset button is parallel with the trim panel top edge" The button is hard to see, but with a flash light you can see a red rubber seal which is the button cover exactly even with the top edge of the trim panel that houses the hood release. This was on pg. 6-3 of my owners manual.
Old Mar 28, 2011 | 09:02 PM
H20boy's Avatar
It looks like its on the other side of the back of the fuse box, based on gus's pdf, the button probably faces downward and can be seen/felt just by reaching under the dash a little bit.
Old Mar 29, 2011 | 07:30 AM
I took a peek under the dash this morning , and didn't find the dang thing...
Mountaincat, your manual must be updated, as my manual shows it where it "used to be".
Thanks for the pics Larry... I knew I wasn't that nuts. ( I work at SDC in SeaTac wa.)
Anyway.. I will take a better look this afternoon. if the fuel shunt ever gets tripped, I am pretty sure I will call AAA and have the car towed home anyway.
Old Mar 29, 2011 | 08:28 AM
jnporcello's Avatar
I hope this doesn't sound too stupid. I have been following this thread and wondering what the inertia switch is for. I'm thinking its so things shut down if the car flips over, but if anybody has a real answer that would be handy.
Old Mar 29, 2011 | 08:38 AM
  #28
Gus's Avatar
Gus
"The inertia switch is installed next to the fuse box in the LH end of the fascia. When activated, it deenergizes the ignition relays in the engine compartment, driver's side fascia and trunk fuse boxes. It also removes ground inputs from the BPM and windshield wiper stalk switch. This stops the engine and fuel pump, unlocks any locked door, and de-energizes unnecessary electrical systems. The switch is reset by pressing down on the rubber cap on the top of the switch".
Old Mar 29, 2011 | 10:31 AM
I believe the inertia switch is called a "roll-over" switch reset in other cars. In my 2006 xkr the switch is on the opposite side of the fascia fuse box, in other words the fuse box mates against the door when closed. The inertia switch is located above the foot rest behind the plastic trim just below the top of the trim. Just feel with your fingers towards the back of the trim and you'll feel the rubber boot (which is red) covering the switch.
Old Mar 30, 2011 | 04:48 PM
  #30
Gus's Avatar
Gus
Did you find it?
Old Mar 31, 2011 | 02:35 PM
  #31
Spurlee's Avatar
Default Advertising
I was pleasantly surprised to learn of this. Mercedes just finished running an ad campaign here in Chicago touting the same feature on their sedans. Perhaps many cars have this, perhaps my 11 year old Jaguar was ahead of its time.
Old Mar 31, 2011 | 10:38 PM
  #32
XK8+XJ8L's Avatar
Size:  1.9 KB Just saw that commercial last week, and those are the same thoughts I had when I saw Gus's post. I guess the MB turns on the 4-way flashers too, but that's not a very big deal compared to the rest of it.
Cheers,
Forcedair1
Sep 8, 2025 01:57 PM
tomsjag
Jun 10, 2023 10:02 AM
explorer364
Sep 14, 2015 07:43 PM
1964Daimler
Sep 9, 2015 11:28 AM
laserguy
Sep 3, 2015 02:02 PM
