Injector wiring rails?
Old Apr 25, 2014 | 01:44 PM
ChuckB's Avatar
Default Injector wiring rails?
1999 xk8. Looking down on the engine there is a rail that contains all the wiring to the fuel injectors on each side. The wires are exposed and it would appear there are suppose to be snap-on covers. I can not seem to find the name or number of this part(s). Any leads will be met with gratitude.
Old Apr 25, 2014 | 02:23 PM
ChuckB's Avatar
I believe what I'm looking at is a V8 engine with missing plastic covers. If I were to find covers, how do they attach?
Old Apr 25, 2014 | 02:48 PM
Fulton's Avatar
If you are talking about the main engine covers, see picture, The part number for the set is JLM21723. They snap on to the 3 long bolts on your cam cover and into the small holes at the base of the fuel manifold. Do a google search for the part number hopefully you can find a used set.
Old Apr 25, 2014 | 05:34 PM
ChuckB's Avatar
Thank you for your guidance... I found the set on Ebay for $65. I can use the saved money to buy more Jag parts.
JWheeler
Nov 22, 2019 08:28 AM
knightofgold
Feb 11, 2016 06:03 PM
ogorir
Jan 18, 2016 10:09 PM
Jagged-X
Sep 24, 2015 05:08 PM
jaguarbill
Sep 5, 2015 11:43 AM
