Intermitant Cruise Control
Old Aug 6, 2012 | 08:09 PM
bluexk8ragtop's Avatar
Good day,
I haven't had my car on the road for very long, so excuse me if this sounds crazy... Did you happen to swap out the rear diff for a different gear ratio? Generally, that would tell the stability control the RPM's and speed don't match, but I would also think that would throw a code...
The only other thing I can think of is you have a tone ring on one of the wheels starting to go... It doesn't stay faulted long enough to throw a code, but will disable the cruise when it blips... Again, I'm not completely positive the cruise system uses the tone rings to stay active...
Good luck!!
Cheers!!
Old Aug 8, 2012 | 12:30 PM
RJ237's Avatar
I'm not sure why, but it's working again. After all the connections and grounds I took apart and cleaned I may have actually fixed it, or maybe it's just on the working phase of the intermittent cycle.
Anyway, I think it's time to close this thread. Thanks for all the help.
RJ_______________
97 XK8 85K mi
MrWhite
19
Jun 14, 2022 07:49 PM
MrWhite
Oct 1, 2015 01:43 AM
leep123
Sep 30, 2015 03:41 PM
Camnelson324
Sep 27, 2015 08:48 AM
zdrapec
Sep 25, 2015 05:49 AM
