Intermittent Windows on XK Convertible
Old Jul 15, 2009 | 12:42 PM
Gus's Avatar
Gus
Originally Posted by man7sell
2000 XKR Convertible. The windows are designed to lower slightly when raising or lowering the top, then automatically raise again.
Mine are intermittent, some times it works and sometimes they just lower without raising again.
Anyone had this problem? Fixes?
Paul
What you need to do is reprogram the window. To do this you push the window down button and hold until you hear or feel a click. Then push the window button for the window to close and hear or feel the click. This should be done when you are in the car and the door is closed. The window should operate properly by opening a slight bit when the door is opened and close when the door is closed.
This problem is often caused by a weak battery voltage. 10.5 or below they loose memory settings.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
jdzubas
Oct 4, 2015 09:14 AM
sadepol01
Sep 11, 2015 05:26 AM
