J gate adjustment problem
Old Nov 27, 2022 | 10:26 AM
Robin Smith's Avatar
Default J gate adjustment problem
Can anyone help with the following issue on my XK8 1998 convertible; I appear to have too much play somewhere in my J gate shifter mechanism. If I adjust the shifter so that it goes properly into D (from P), when I then shift across and into 2 or 3, it will not shift properly back into 4 (from 2 or 3). If I adjust to get the shift from 3 to 4 to work, I then struggle to get into D from P. This problem also seems to get worse when everything is up to normal running temperatures. The J gate shifter itself seems OK in that I can see a small movement in the J gate end of the cable when I apply a small movement to the shift lever itself. Can wear and play develop in the gearbox end of shifter cable or could it be a worn detent mechanism in the gearbox itself?
Old Nov 27, 2022 | 02:44 PM
rod9669's Avatar
Have you adjusted it in the correct position i.e. on the large nuts, not on the inner cable end?
See here
http://jagrepair.com/images/TSB/307-01-1.pdf
Old Nov 27, 2022 | 03:08 PM
See here
Yes, but I am only attempting the adjustment from within the car, I haven't got underneath to check out the gearbox end yet.
Old Nov 28, 2022 | 01:56 AM
rod9669's Avatar
You need to disconnect it from the gearbox lever to get its neutral position , should be ok once you've done that - follow all the steps
If it's still not right then there'll be an issue with the J gate itself, not that there's much to go wrong with either the J gate or the cable tbh
Let me know how you get on
TBanks98
Sep 1, 2021 08:04 PM
prodigy215
19
Sep 10, 2015 12:37 PM
Road Racer
Jul 18, 2015 11:41 AM
Lugnutty
Aug 30, 2014 03:47 AM
guenzak
Mar 23, 2008 09:23 AM
