Jaguar XK TSB's
Old 05-19-2010, 07:07 PM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
Originally Posted by Harley D.
Hi Gus,
Nice to hear from you. I don't really need anything, thanks.
But I spotted your post on MPC regarding the frustrating "Navigation DVD" issue -- which provided a link to this site -- and I was unable to open your attached PDF file in message #49. So I joined the Forum, and still couldn't open anything. It was while browsing that I discovered Matt's reminder to new members.
Don't know if I'll ever get to the requisite ten posts in order to obtain "permission," considering my inactivity of late. However, I still try to stay informed, and follow select topics.
Hello to all who remember me from elsewhere. You're in my thoughts, even though I'm no longer an active participant.
Harley D. - '03 XK8
Southern California
Good to know that you are looking over our shoulder. If you see my post say hello and that will bring up the post.
Old 06-10-2010, 09:52 PM
pdog2000's Avatar
aahhh i get it...sorry i emailed you guys, i feel like a total knob now
Old 08-02-2010, 07:20 PM
wnenn's Avatar
The ten post rule is an issue if you have joined the forums to get answers as I did. I don't have a lot of luck talking about stuff I know nothing about till I can look at some of the items I've inquired about. I know these are the rules but.....
Old 08-21-2010, 11:17 AM
snuggles's Avatar
Default 2007 xk
Hey Jim, I just purchased a used 2007 XK and bought a K&N air filter. It looks like the air filter box is located low behind the left headlight in front of the left front tire. Do you know the best approach to access the air filter box??
Thanks,
Pete Russell
Old 10-12-2010, 12:56 PM
WhiteXKR's Avatar
Received 2,981 Likes on 2,123 Posts
Default 2000-2002 XKR EGR tube update/replacement TSB
The original 2000-2002 XKR EGR tubes often cracked. Now there is an updated part. This is the factory TSB for this procedure.
File Type: pdf
The following 3 users liked this post by WhiteXKR:
DesertXK8 (12-06-2016), Dr Quail (07-20-2016), NiceCat (12-01-2013)
Old 10-13-2010, 08:50 AM
iriddles's Avatar
Default TSB Number
What is the TSB # for the cracked EGR pipes?
Old 10-14-2010, 07:35 AM
WhiteXKR's Avatar
309-S501
iriddles-
Post 4 more times and your post count of 10 should allow you access to the file. If you just welcome some new members in the new members section you can get there quickly.
  #28
Old 10-14-2010, 11:58 AM
iriddles's Avatar
thanks whitexkr!!!
  #30
Old 11-10-2010, 09:58 AM
Don Neff's Avatar
Default TSBs
Thanks for posting the TSB files!
  #31
Old 11-10-2010, 10:01 AM
Don Neff's Avatar
I agree. I can help all you need with an XJ-S, but I am new to the XKR and need to learn.
  #32
Old 11-10-2010, 01:28 PM
H20boy's Avatar
Received 1,144 Likes on 750 Posts
The 10 posts fly by when you chat about other member's projects, ask a question or two, and welcome other new members in your same situation as a newbie. The XJS section can always use more knowledgeable owners.
  #33
Old 12-16-2010, 12:44 AM
anjy834u's Avatar
Default thanks
Originally Posted by JimC64
Headrest tsb as advised by Doug. Nice one
Fuse charts, convertible top, trasmission control module and tensioners as advised by Test point - many thanks
thanks for info
  #34
Old 12-16-2010, 12:48 AM
anjy834u's Avatar
Default xk cost
convertible top electrical system as advised by Gus - thanks Gus
Throttle body service action by Test point - Cheers
Technical Service Bulletin 417-05 (install a vent to lower headlight condensation issues)
ZF-adaption-TSB
could u give me the cost of jaguar xk ?
  #35
Old 12-16-2010, 12:49 AM
anjy834u's Avatar
Default same issue
Originally Posted by RSA Esq
Hi Jim,
I am unable to open any of the TSB attachments in your post. Is there something else I need to do to access them?
Many thanks!
Ray Armstrong
Huntington Beach, CA
am facing the same issue
  #36
Old 12-16-2010, 12:50 AM
anjy834u's Avatar
Default adobe
Originally Posted by djpxk8
unable to open any of the docs
regards,
david
may be u need to install adobe reader
  #37
Old 12-16-2010, 12:52 AM
anjy834u's Avatar
Default true
Originally Posted by scm
Save the files and open them locally. It'd help if you said which OS and browser you're using as the advice may vary for different systems and apps.
yes differentt options
  #38
Old 12-16-2010, 12:54 AM
anjy834u's Avatar
Default adobe reader
Originally Posted by seaside1
This is a Word file. I am using Firefox and Windows 7. I have Word 2003 (with a converter for Word 2007) I see no way to open this file or to save it to my hard drive. If someone knows how to open it, please let me know...Thanks
try adobe reader
  #39
Old 12-16-2010, 12:55 AM
anjy834u's Avatar
Default Tsb
Originally Posted by test point
I don't know why you are having trouble downloading the Word file but here it is in .pdf.
Bottom line is that the TSB was issued in August '99 at the start of the '00 model year. If your car was assembled after that you should have the green Pentosin fluid. Check the manufacture date on the driver 'B' column. Check the color of the fluid in the reservoir. The earlier fluid was yellow. Top up if low and green, flush if yellow.
There is also a common problem with the top lift rams leaking without much sign of escaped fluid. If reservoir is low you have a leak that must be fixed.
Also an excellent time to install the pressure regulating system before you blow the hoses which I am surprised hasn't happened yet. Mine blew at 40k mile, 4 year intervals like clockwork . . . three times.
WHAT EXACTLY IS tsb ?
  #40
Old 12-16-2010, 12:56 AM
anjy834u's Avatar
Default Thanks
Originally Posted by h20boy
Remember, new members, with less than 10 posts and 3 days of membership (both must be achieved) cannot download or view 'attached' documents. Please read the New Member thread as the MUST READ for all new registered members.
thanks.
thanks for reminding
Quick Reply: Jaguar XK TSB's
