Jaguar XK8 Convertible Drivers Window Faulty
Old Sep 1, 2024 | 10:57 AM
Fenners's Avatar
Default Jaguar XK8 Convertible Drivers Window Faulty
I have a problem with the drivers door window. when I open the door the window drops as it should but when I release the door handle it raises back up. this means the door will not close,
Old Sep 1, 2024 | 02:55 PM
Jag#4's Avatar
Have you tried resetting the windows?
Lower window and continue to hold button until you hear a slight click. Release button and then raise window, while holding the button, until you hear that click. Do this on both sides.Then see if that fixes your problem.
Mine occasionally forget and need to be reset. I think my battery is due for replacement.
Old Sep 2, 2024 | 04:15 AM
Fenners's Avatar
thanks for info. I know about the reset that's not the problem
regards
nigel
99xk8guy
Sep 29, 2025 10:51 PM
Ant Buck
Dec 12, 2022 11:07 AM
Joexkr2001
US Northeast
Mar 2, 2022 04:25 PM
justenough
Feb 7, 2018 01:42 PM
garver
Nov 4, 2010 04:57 PM
