05 Unusual Window Problem
Old Nov 3, 2010 | 09:46 PM
garver's Avatar
Default 05 Unusual Window Problem
Hey guys I just bought my 2005 XK8 a few weeks ago and I am having some window problems. My drivers side window will not go up or down automatically when I open/close the door. I have tried resetting the window memory but it did not help. Anyone have any idea what else could be the problem? I have also noticed that the window will atleast go up when the door is shut, but it is very rare.
Thanks for the help in advance.
Old Nov 3, 2010 | 10:01 PM
Reverend Sam's Avatar
Just so I'm clear on the problem, you're saying that when you pull on the door handle the window doesn't drop down about half an inch like it's supposed to? Or does it drop down and then go right back up as soon as you release the handle?
Does the dashboard show that the driver's door is open when you open the door?
I'm asking these questions because there are two microswitches that control the window. One of them causes the window to drop when you pull on the handle, the other one causes the window to stay down until the door is closed again. You can tell if the second switch has malfunctioned because the dashboard will not give you the door ajar warning if the second microswitch is bad. If you are getting the door ajar warning but not getting the window to drop when you pull the handle, then it sounds like the first microswitch is bad. Or, it could be the window controller thingy (I forget what it's called, but it's the electronic box that controls the window operation).
Old Nov 3, 2010 | 10:11 PM
garver's Avatar
It doesnt go down when the handle is pulled. I just went and tested the door and the dashboard is not giving the door ajar warning, so I guess it has to be that microswitch, thanks for the help.
Old Nov 3, 2010 | 10:13 PM
garver's Avatar
So in order to fix this am im guessing im going to have to replace the door latch assembly?
Old Nov 3, 2010 | 10:26 PM
Hmmm... that's weird. It could be that both microswitches are defective, or there might be a problem with the door control module. The DCM is back behind the speaker and it tells the window what to do. Since the window still goes up and down it seems less likely that the DCM is bad, but you never know.
The latch is a pain in the butt to replace, and it costs $750 from the dealer. I saw a used one on eBay for $150, but it is only for cars through the 02 model year. I'm not sure where that first microswitch I described is located. I don't think it's in the latch because I didn't see it when I had my latch out. But, It sounds like you need the second one (the one in the latch) replaced for sure ... unless it's the DCM.
Both doors have a DCM. I don't know if they are swappable. Another member will have to answer that question. If they are, then you could swap the two DCMs and see if the problem moves to the other door. If so, then you could just get a DCM from a junk yard. That would be the easiest fix. Or, if you don't carry passengers very often, you could just leave the DCMs swapped and not worry about it. But first we need to figure out if it's the microswitches or the DCM.
Old Nov 3, 2010 | 10:28 PM
While we're on this subject, does any other member know why a 2002 door latch assembly wouldn't work in a 2003? Did Jaguar really redesign the door latch between 02 and 03?
Old Nov 4, 2010 | 07:00 AM
steve11's Avatar
ud
The PATS security system was changed in 2003 on the XK8 and I believe that changed all the access locks.
Old Nov 4, 2010 | 12:55 PM
garver's Avatar
So this morning I drove the car and the window didnt work, but now it is working only when the door is opened very slowly, im wondering if the window is out of aligment and is getting stuck a bit in the trim until the door is opened a bit causing it to jar loose.
Old Nov 4, 2010 | 02:59 PM
Do you have a copy of the JTIS? It has pretty good instructions on how to adjust the window.
Old Nov 4, 2010 | 04:57 PM
garver's Avatar
no but I believe its in the faqs and I know that someone recently made a youtube video of it. Im not going to be able to tackle this until tuesday but ill update this post if it works.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
fingers
General Tech Help
Oct 21, 2015 02:02 AM
laserguy
Sep 3, 2015 02:02 PM
