Jaguar XK8 Fuel Gauge Problem - Video inside
Old Oct 7, 2012 | 10:52 AM
tanngo's Avatar
I was thinking maybe this dirty float ... behaves differently each time, usually fall when the car stops. similar experience ¿ i have to import spare parts , very few jaguar argentina .
Old Oct 11, 2012 | 06:05 PM
tanngo's Avatar
xkr 2001 , ARGENTINA .
I continue with fuel gauge problem, suddenly stops working, sometimes it works, sometimes not, reset. I have no spares in Argentina, I import them. can accommodate floating and fixed
Old Oct 11, 2012 | 06:17 PM
Gus's Avatar
Gus
Well it is Thursday and still have not had time to replace the tank fuel float and it looks like I may not get to it until mid next week. I am so sorry I put you off, I had all intentions of getting it done as promised and posting the results if I am correct and all went well. I am up to my elbows trying to get things done at the new house. I had no idea that our to-do list was that detailed.
Old Oct 11, 2012 | 06:34 PM
tanngo's Avatar
thanks gus, no problem, I have the illusion that float arrelge alone, I think it may be dirt, I'll wait for your footsteps, I am a follower of your website and helped me a lot.
write and read with google translator . gracias amigo .
Old Oct 11, 2012 | 07:57 PM
Gus's Avatar
Gus
Looking at the new float and seeing it is a potentiometer I see how it could fail. I think with the number of fill-ups and bouncing around in the tank it would take a lot of abuse over time. This is my new float and I would not know if my theory is correct until I remove the old one. I made a few tests on the system to verify that my problem was not anything other than the float.
Attached Thumbnails Jaguar XK8 Fuel Gauge Problem - Video inside-fuelfloatw.jpg   Jaguar XK8 Fuel Gauge Problem - Video inside-fuelfloatw2.jpg
Old Oct 11, 2012 | 10:14 PM
tanngo's Avatar
gus, excellent, thank you again, you understand, was what I needed to know, I will expect you to pull your float, good photo.
Old Oct 12, 2012 | 10:42 AM
tanngo's Avatar
fuel tank can be moved? sender to inspect, without drawing lines down? Xkr 2001 cabrio . Google traductor.
Old Oct 12, 2012 | 03:11 PM
  #28
Gus's Avatar
Gus
Drain the tank if you are going to pull the float, remove the tire cover in the trunk and the fabric that is against the tank below the rear window. In the middle of the tank is your fuel tank sending unit with a black and red wire attached to it.
Attached Thumbnails Jaguar XK8 Fuel Gauge Problem - Video inside-fuelfloat3.jpg
Old Oct 12, 2012 | 03:58 PM
tanngo's Avatar
xkr 2001 equals the 2000 xk8 system?? 'm disarming! I just go by jag repair replacement fuel pump
Old Oct 12, 2012 | 04:08 PM
  #30
Gus's Avatar
Gus
If you are asking is the 2000 the same as 2001 I am unsure you will need to check on that.
Old Oct 12, 2012 | 09:39 PM
  #31
tanngo's Avatar
jagrepair guia ..
I'm making tool to disconnect lines tank .. I have a little gallons of gasoline in a car, will be poured to disconnect? xkr 2001. thanks
Old Oct 13, 2012 | 08:14 AM
  #32
Gus's Avatar
Gus
If you are looking to replace the fuel pump then you need to remove the tank and to do that you need to remove the fuel lines, if you are replacing the fuel level indicator you do not need to remove the tank only the fuel.
Old Oct 13, 2012 | 09:38 AM
  #33
tanngo's Avatar
Gracias Gus , 2001 xkr convertible, I see no other way to reach floating equals xk8 2000 pictures jagrepair
Old Oct 13, 2012 | 02:16 PM
  #34
Gus's Avatar
Gus
The photos are for a 1999 but the only difference between accessing the fuel level indicator is that the model year 2000 and up has a metal cover at the tank that needs to be removed and you will see this when you remove the cover in photo #3. I hope this helps.
Attached Thumbnails Jaguar XK8 Fuel Gauge Problem - Video inside-fuellevellocation1.jpg   Jaguar XK8 Fuel Gauge Problem - Video inside-fuellevellocation2.jpg   Jaguar XK8 Fuel Gauge Problem - Video inside-fuellevellocation3.jpg
Old Oct 13, 2012 | 02:54 PM
  #35
Paul Pavlik's Avatar
Gus, in another post, a 2000 XKR Coupe is shown as having a Sending Unit included in the Tank Top assembly:
https://www.jaguarforums.com/forum/x...bwoofer-70631/
(Post #12 by toyman)
However, the sticker on that tank indicates that it's actually a 2001 XKR. Also, that it is a ROW (non US) unit.
My 2000 XKR Coupe does have the Sending Unit on the Rear of the Tank but i think that the 2001 and up cars have it in the Tank Top Assembly.
My Sending Unit is intermittent and I have a new Sender to install as soon as the Fuel Level is low enough.
Old Oct 13, 2012 | 03:33 PM
  #36
Gus's Avatar
Gus
Thank you Paul. I could be wrong on this but I was not sure if we were having a communication problem with him or me. If you are correct and I think you are he will know the moment he pulls the cover and it is not there. The subtle changes between cars at time can confuse me but I get confused easily.
Old Oct 13, 2012 | 05:53 PM
  #37
tanngo's Avatar
Jaguar xkr. 2001 argentina Google traductor Gus , I want to thank you for your time and advice! I managed to remove tank, remove floating ... had dirty contacts corrocion dull. Ok now.
Old Oct 13, 2012 | 05:59 PM
  #38
tanngo's Avatar
Google traductor , thanks paul, my jag equals who described paul post, remove lower lines, tank, cap top, two bombs inside, floating slightly dirty and bend metal ...
Old Oct 13, 2012 | 06:08 PM
  #39
tanngo's Avatar
perform the same work the post of Toyman, the difference was remove tank, no place in Convertible jagrepair lead me to change fuel pump ..
Old Sep 6, 2014 | 06:00 PM
  #40
rgcurrin's Avatar
Default XK 8 fuel sensor problem
My 2001 XK 8 has the same issue. The code reader says it is the "low fuel level sensor" . Not sure what that is, other than what the name suggests. If it can be fixed for $100 or less, OK; if not, I'll just continue to monitor the odometer.
