Late XKR - confirming mileage is genuine
Old Feb 14, 2024 | 08:24 AM
Lambo_xx's Avatar
Default Late XKR - confirming mileage is genuine
Hello, I’m new to this forum so hopefully some of you can advise me.
I’m currently searching for a low mileage X100 XKR (2005 or 2006), is there a way to confirm the mileage is genuine? For example on Ferraris from this era the mileage was also saved in the gearbox & many newer style cars it’s also saved in the key.
Does anyone know where we can check to confirm the mileage?
Thanks in advance
Old Feb 14, 2024 | 08:48 AM
RichardS's Avatar
Thanks in advance
I think that the mileage shows up in an ODB scan if your scanner is a good model.
Richard
Old Feb 15, 2024 | 01:29 PM
Lambo_xx's Avatar
Ok thank you. I’ll do some more research.
Richard
Old Feb 15, 2024 | 01:31 PM
michaelh's Avatar
If it is UK-registered you can look up history here:
https://www.check-mot.service.gov.uk/
Old Feb 15, 2024 | 01:32 PM
xalty's Avatar
cluster only
if they put a new cluster in or eepromed it you will never know without service records
Old Feb 16, 2024 | 02:51 PM
Y2KJag's Avatar
Are the XKRs that valuable? Valuable to the point of going through the brain damage of re-chipping the cluster, or whatever, in order to fake the mileage?
I know the XK8s wouldn't justify it unless perhaps it was some particularly rare specimen. But I have no idea about the XKR.
Old Feb 16, 2024 | 04:35 PM
farm-jag's Avatar
I question this also. I would say that there's no much more of a risk with an XKR then what is probably average risk of this happening. I think I would at least pull a Carfax or similar and sort of match up with what is in the cluster currently and see if it makes sense. I think by and large if it's off enough to be an issue it will be pretty obvious with these few things.
TheTruth
Sep 11, 2025 07:04 AM
London Kenton
Mar 24, 2020 04:07 PM
prettybluefin
Oct 30, 2017 09:33 PM
Redeye
Jul 26, 2017 02:54 AM
Salu498
Apr 22, 2016 06:36 PM
