Leak-down test 20-25%
Old Apr 28, 2011 | 09:39 PM
Genomac's Avatar
Default Leak-down test 20-25%
Hey everyone. I just bought a 97 Xk8 w/75k miles. I had a leak-down test on it and the readings were 20-25%. Is this normal for the xk8? How long do you think that engine will last? Another 25k maybe?
I am about to spend $2,400 on tensioners + water pump + tstat etc. Should I just drive it until the tensioners give and do a rebuilt at that time?
Thank you,
Gene
Old Apr 28, 2011 | 09:55 PM
cheaperts's Avatar
NO! These engines are not rebuildable as far as I understand, and if they fail more then likely it will destroy the engine, fix those tensioners. If the compression is still good on it then it should go a long way if you maintain it. Standard procedure for our vintage of motor is to change these issues (tensioners, water pump, thermostat riser) to the updated/better parts and then loving maintain the car. By the way, you will LOVE driving the car once you get to really enjoy it, only problem I have with my 99 is the pain it causes in my cheeks, can't get rid of that grin..........
Old Apr 28, 2011 | 09:59 PM
cheaperts's Avatar
Also, if you readon here you'll find many cars in the mid 100,00's to even pushing 200,000. Some folks believe a healthy nikasil engine will actually outlast the steel sleeved engines
workworkwork
Oct 1, 2015 01:44 AM
leep123
Sep 30, 2015 03:41 PM
pnwrs2000
Sep 30, 2015 01:56 PM
ziondio
Sep 29, 2015 01:58 PM
