Leaking Fuel Rail pulse damper - OMG noo!
Old Sep 22, 2017 | 10:58 PM
  #61
silverXKR03's Avatar
Did replacement of dampers only fix your problem? I have the top of my 2003 XKR torn apart right now due to random fuel smell during startup in cooler temps. Looking at the fuel rail I do not see any obvious sign of a leak at the damper, did you see any discoloration on yours?
Old Sep 23, 2017 | 08:12 AM
  #62
STRV8's Avatar
Hi,
My dampers leakage was seen visually when engine turned on. After few minutes tripping stopped. And yes, dambers change did the job. No discoloration seen on dambers, seal was leaking. Had to replace leaking egr pipe, coolant reservoir etc at the same time
Old Sep 23, 2017 | 08:51 AM
  #63
fmertz's Avatar
FWIW, the occasional fuel smell on my car ended up being from the fuel pressure sensor at the end of the rail. $60, 2 screws, a vacuum line and a connector. 10 min job. Best of luck to you.
Old Sep 23, 2017 | 06:25 PM
  #64
Thanks strv8 and fmertz I took out all the fuel injectors gave them a clean and checked the seals to the fuel rail and they all look good added a little silicon grease for reassembly. I will take apart dampers and check seals tomorrow. Also thought about fuel pressure switch I actually took it out to inspect it, where was yours leaking from, doesn't look like any kind of seal on thread.
I do want to be sure I have it figured out before putting her back together. Also what are the correct part numbers for valley hoses the one closest to driver (LHD) is correct the passenger side I purchased AJ86326 which is not the right one.
Paul
Old Sep 23, 2017 | 09:21 PM
  #65
Just realized I was looking at wrong sensor, there is one at the end of the fuel rail, maybe some sort of temp sensor which explains lack of seal, will check out the actual pressure sensor too.
Old Sep 24, 2017 | 08:46 AM
  #66
fmertz's Avatar
There is a fuel temp sensor and a fuel pressure sensor. The leak on my car was from the pressure sensor. It leaked from the "body". As the smell occurred, it tried to locate the leak (nose, fingers) until I came across the wet body of the sensor. It looks like the sensor can be taken apart (possibly), as the shell appears to have snaps, but I did not attempt anything. The sensor fits into the rail with 2 tiny o-rings. As the entire body was wet with gas, I figured the damage was beyond these cheap o-rings. Besides, I am allergic to fuel fires, and figured a properly sealed fuel sensor was money well spent!
There is also a fuel temp sensor (I think it helps for hot restart, vapor lock, etc.). I saw it on the diagram, but know nothing about it.
Best of luck in your project.
Old Sep 24, 2017 | 03:37 PM
  #67
Thanks, having a look now. I will let you know what I find.
Old Sep 26, 2017 | 02:26 PM
  #68
STRV8 what is the part number for the damper you used AJ84080 mentioned in post doesn't have the tabs in the pictures I saw.
Old Sep 26, 2017 | 10:19 PM
  #69
STRV8's Avatar
Hi, it was AJ83838 if I remember rightly.
Old Sep 27, 2017 | 03:15 PM
  #70
Thanks, ordered some this morning. The thought of taking all this apart again if seal only fix didn't work just isn't worth it.
Got to detail the engine while waiting, also did valve cover gaskets, valley hoses and putting a powerhouse pulley on after rebuilding snout. Will be nice when complete.
Thanks again for your help.
Old Sep 27, 2017 | 10:09 PM
  #71
maxwdg's Avatar
Default Hi guys!
As the originator of this thread, I get about one email each month about those pesky leaking dampers. My last word advice: Please don't waste your time trying to refurbish a flawed and totally unneeded system.
You're going to be taking the top of the engine (SC variety) anyway, so don't risk the ton of work to do the job twice. Pull the fuel rails and have the damper cups tig welded closed. You car absolutely does NOT NEED them.
Old Sep 27, 2017 | 10:40 PM
  #72
STRV8's Avatar
Hi,
My dampers vere fine +15 years. My indy(former professionally trained Jag mech) did this job and little more in 2.4 hours start to finnish to STR. Hope new ones will last the lifetime of the car.
Old Oct 12, 2017 | 09:47 PM
  #73
Just an update. I finished the job a couple of days ago part # AJ83838 (pulsation damper for 4.2) got them for about $113 each, did the trick, no more gas smell.
Also replaced valley hoses while I was in there, I know a lot of people worry about these, I have to say mine looked like they had a lot of life left in them at 88,000 miles, still while you are in there you would be foolish not to.
Also rebuilt supercharger and installed 2.5 lbs pulley and cam cover gaskets so should be set for a while.
Thanks again for all your help, anyone with the same issue that ends up reading this thread don't fret, there is an answer without the need to buy a complete fuel rail.
Thanks again all!
Old Oct 13, 2017 | 08:54 AM
  #74
STRV8's Avatar
Hi,
Nice to hear that problem is solved and kitty is purring again !
Old Nov 1, 2017 | 12:57 PM
  #75
cutthesteel's Avatar
I continually see this issue among these cars, with numerous solutions. I "fixed" mine several years ago with fuel tank sealant and epoxy. It lasted a few years and has just started leaking again. I am leaning towards elimination of the component this time... cut 'em off and weld it closed....
Old Nov 3, 2017 | 09:03 AM
  #76
It has only been a few weeks, but after damper replacement still great, weather turned colder too which was always the worst time. I would anticipate at least the 14 years the original ones lasted. Also once I replaced them and saw how the new ones pressed in, I do believe the problem is with the blue o ring, you can see the change in color where they have been seated. If it were possible to get the exact same seal, next time around I would try that. First attempt, the thought of having to do it all again was too much of a risk I didn't want to take and first start up was a nervous one.
RoyLittle0
May 25, 2023 02:38 AM
Bcrary3
Feb 21, 2023 04:29 AM
OkieTim
Sep 8, 2015 04:48 PM
Tar
Sep 6, 2015 11:24 AM
OkieTim
Sep 2, 2015 12:48 PM
