Leather behind door pocket
Old Apr 25, 2026 | 01:36 PM
Newjagforme's Avatar
Default Leather behind door pocket
Hi everyone. Looking for some advise. The leather behind my door pocket on the drivers side door is sagging, and I am trying to figure out the best way to fix it. From what I can see, if I remove the door panel, there is no leather showing on the back, and the door pocket looks like it is riveted to the door panel. Has anyone had this issue, and if so, how to repair? I have not removed the door panel yet, and I am going on information based on others peoples work in YouTube videos. Thanks in advance.
Old Apr 25, 2026 | 09:36 PM
LMG's Avatar
LMG
If I read your description right, I had the same issue when I bought my XKR. I was able to tuck the leather back in place after removing the door card and taking the plastic door pocket off. I honestly don't recall if the pocket was riveted, but however it was attached can't have been too bad to deal with or I would have remembered.
This photo may help:
Old Apr 26, 2026 | 06:45 AM
Thank you. I will try it this week.
Old Apr 26, 2026 | 07:42 PM
Throwback's Avatar
I have done this repair. Two things - buy replacement foam backed fabric in the right colour first. You will need this to reupholster the fabric bit, which will be disintegrating and you'll kick yourself for not replacing it while you have it all apart and easy to re-do nicely. Second, remove the door card then you need to dremel the heads of the melted-in plastic rivets to release the door pocket/handle section. Then you can then separate the pocket from the door card and re-glue the leather and replace the foam back fabric, gluing with contact adhesive. Then reassemble and either plastic weld the rivets up again (get a plastic welder) or use epoxy to re-seal them. I used epoxy. plastic welder would give you more material to work with if you ever had to repeat the process.
Old Apr 26, 2026 | 08:02 PM
Thanks for the advice, really appreciate it.
jbretthorton
Jan 15, 2025 01:13 PM
Catmobile
Aug 19, 2024 11:34 PM
viper1996
Apr 30, 2019 11:28 PM
Texasbill
Nov 20, 2018 10:26 AM
jahummer
May 20, 2011 04:49 PM
