Lens moisture
Old Nov 4, 2010 | 11:30 AM
Dr No's Avatar
Default Lens moisture
Tuesday I purchased a 2003 XKR, and I notice there is moisture/condensation in both front light lens covers. Is there a recommended method of removing the moisture?
ajn
Old Nov 4, 2010 | 11:43 AM
anthonyisd3ad's Avatar
ajn
i dont know how your headlights are but im pretty sure theyre the same as my 98 xk8. when you open the hood look at the back on the headlight. youll see a giant clear plastic piece. simply unclip it and remove the plastic. after driving around a little it will clear out the condensation. im pretty sure you can leave the plastic off without having to worry about getting water in the headlight as well.
Old Nov 4, 2010 | 11:44 AM
2002XK8Orlando's Avatar
There is a TSB for this where a vent hole is put into place It is in the FAQ section
Old Nov 4, 2010 | 11:57 AM
brgjag's Avatar
I just took mine off. Just got to remember to cover opening when I clean motor.
Old Nov 4, 2010 | 05:02 PM
cpm53's Avatar
I have an 03 XKR and I had the same problem. I had a dealer install the vent tubes and it cost about $100 but it worked...regards...
Old Feb 27, 2011 | 01:00 PM
jwilkins's Avatar
Default RE: Lens Moisture
Where are those vent tubes?
I just purchased a 2002 XK8, and I also have moisture inside both headlights. Since I live in the Seattle (aka Rainforest) area, I need to get this handled. I am sure I can dry these babies out during the few days when it's not raining here, but I need a long-term solution. I wanted to find out if the previous owner had these vent tubes installed. Thanks.
James
BoarHawg
Dec 14, 2015 12:21 PM
Hoppy
Oct 2, 2015 08:12 AM
Hoppy
Oct 2, 2015 04:00 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
NCJagman
Sep 28, 2015 10:31 AM
