Light for A/C display gone out
Old Jan 18, 2011 | 10:49 PM
npopowitz's Avatar
Default Light for A/C display gone out
I've got a 2005 XK8. Recently the light on the display for the A/C has gone out, which is particularly inconvenient at night. Is there a particular fuse for this panel, or should I assume the panel light is shot? If the latter, how does one go about replacing the unit?
Old Jan 25, 2011 | 05:03 PM
Mike X's Avatar
Hi , this is just a stab in the dark , but on some cars if the fan is turned right down or off the air con cuts out ? good luck.
Mike.
Old Jan 26, 2011 | 11:26 AM
npopowitz's Avatar
Thanks Mike, but the A/C and heat work just fine, both manually and on auto. Just the light is out. I guess I'll mention it at my next service visit.
Old Jan 26, 2011 | 11:32 AM
Gus's Avatar
Gus
this link might help http://www.modulemaster.com/en/index.php
Old Jan 1, 2012 | 01:55 PM
xk8florida's Avatar
Default link
Gus... just wondering how that Link could help solve a a/c display light out ?
Old Jan 1, 2012 | 02:19 PM
Skid Mark's Avatar
The two light bulbs are probably burned out. You have to remove the center console which allows you to unscrew the radio stack and pull out the climate controller. Then you open up up controller and change out the bulbs.
Reverend Sam has a video on it here: Replacing the Climate Control Bulbs on a Jaguar XK8 - YouTube
Old Jan 1, 2012 | 02:31 PM
Gus's Avatar
Gus
Sorry wrong link! This will help Jaguar I-pod Install I hope.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
OkieTim
Sep 8, 2015 04:48 PM
tberg
Sep 7, 2015 07:32 AM
OkieTim
Sep 2, 2015 12:48 PM
