low beams and ICE not working
Old Oct 20, 2012 | 05:38 PM
Charlie Galea's Avatar
Unhappy low beams and ICE not working
Hello guys , I have a problem with my front low beam,left and right. They were working perfectly 2 days ago, yesterday I changed the tail light bulbs and now the low beams don't work oh and the ICE has no power either any ideas would be appreciated. I had to start with a booster pack the today because i left key on - car is now working fine - apart from no power to the radio and low beams, does this mean the radio is kaput or any ideas of what I can do? Thanks
Old Oct 20, 2012 | 06:18 PM
WhiteXKR's Avatar
If you started with a booster pack, your battery will not come to a full charge unless you drive on the freeway for a couple of hours. You need to charge it.
Disconnect it when you charge it, and then reconnect it...this will also effect a reset of the computers, which may also be needed after running at low voltage.
If this does not solve your problems, then we can start looking at other things.
Old Oct 20, 2012 | 08:40 PM
H20boy's Avatar
I agree with advice above. So yah, that's a +1
Old Oct 21, 2012 | 01:07 PM
Thumbs up thanks
Thanks guy found it was a 10amp fusefor the ICE and a lose relay for the headlights, all is fixed. thanks
Forcedair1
Sep 8, 2025 01:57 PM
afterburner1
Dec 16, 2015 12:12 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
philwarner
Sep 5, 2015 10:05 AM
laserguy
Sep 3, 2015 02:02 PM
