Low coolant level light on.. But, there's plenty of coolant
Old Sep 11, 2019 | 07:34 PM
Ledmi's Avatar
Default I bought this model from CARID in USA
Perfect fit and work perfectly
https://www.carid.com/uro-parts/engi...mjd4400ab.html
Old Sep 12, 2019 | 11:07 AM
funracer's Avatar
Originally Posted by dan314
After checking to see that coolant level is up to neck of tank but before buying new tank, stick your longest finger into tank toward back and see if you can feel the sensor. If it’s the magnetic “donut” on a post type, you may be able to flip/ move the donut up and down and spin it around a few times. Don’t know for sure what was restraining the donut from moving freely but it worked for me. Lights been off for 5 months now.
This worked perfectly for me. First time I just spun the doughnut around on the hollow shaft. No change still had the low coolant light. The hollow shaft felt rough like it had some contaminant on it. Tried again and put downward pressure on the doughnut. It unstuck and slid to the bottom of the shaft. No more light!! Of course it is important that the doughnut be able to move up and down the hollow tube so that you will get the proper indication if you do lose coolant. I will probably try to run a small terrycloth around it and work it back and forth to clean off whatever is crudding up the tube.
Old Sep 12, 2019 | 11:44 AM
nedmonds's Avatar
Thanks for the suggestion, I'll try this first before replacing the tank.
Old Sep 12, 2019 | 11:45 AM
nedmonds's Avatar
Thanks for the link.
Regards,
Neil.
Old Dec 10, 2019 | 02:34 AM
M-e-l-l-o-w's Avatar
Whatever coolant you use it is important not to mix the types/colours.
If you do mix the two it can congeal into a sort of gel causing all sorts of coolant issues.
So if you do change make sure the system is fully flushed out.
Or just always use the correct long life coolant.
Also see this technical bulletin:
http://www.jagrepair.com/images/TSB/...nt%20(XLC).pdf
Old Mar 30, 2022 | 08:02 AM
MLM's Avatar
MLM
Originally Posted by Ledmi
Thanks for the lead, did the Carid unit actually include the sensor? I read the information and saw that the sensor was included. Other tank sources did not.I just want to be sure.
Old Oct 12, 2024 | 09:54 AM
bobg's Avatar
Default is the front of the xk8 facing up or down the rise?
Originally Posted by Greenbrook22
I went to purchase a new sensor. Parked the car on an uphill slope. Came to leave and the current sensor is now functioning correctly after two weeks of showing low coolant. A little rise helped??
Old Oct 12, 2024 | 01:08 PM
  #28
RichardS's Avatar
It's a few years since Greenbrook22 was last active on here.
Richard
Old Oct 18, 2024 | 03:13 PM
Ray J III's Avatar
Default Low coolant light
Mine comes on occasionally. When I open it up it is a cup or 2 low. Not sure why it comes on but it makes me think to check it more often.
Ray
blaydes99
Aug 27, 2021 02:58 PM
G.M. Webster
Dec 11, 2019 09:28 PM
cdma
Nov 27, 2019 11:19 PM
vdpnyc
Oct 3, 2016 02:29 AM
skanoski
Mar 24, 2009 08:18 PM
