Low Oil Pressure, Engine Rattle
Old Jul 30, 2023 | 06:16 PM
XKHawk's Avatar
Any AJ27 Normally Aspirated 4,0 engine from X100/X308 will fit.
The later engines did have the MORSE STYLE silent running chains and the timing/oil pump/blocks are different but an ENTIRE engine is plug and play.
Just some internal parts are different.
Thanks, I also should've asked for any opinions on which would be more recommended - the 135k '01 from an XK8 or the 89k 99 from the XJ8? These internal items vary between the 99 & 01?
Old Jul 31, 2023 | 01:23 AM
Pistnbroke's Avatar
You should have it out in a day .I would pull it with the gearbox if we are talking the scrap car . More care needed on the XK8.You did not say if you have any lift. At a minimum you will need some big ramps and a rattle gun+ engine hoist.
Dont make the mistake of another member ...Put the manifolds on before you put it in !!
92/93 XJS
Mar 23, 2021 08:02 PM
wwilson0704
Feb 7, 2021 11:35 PM
Serlock
Mar 20, 2016 02:07 PM
chri15d
Dec 2, 2015 02:32 PM
blackwolf560
May 3, 2012 04:50 PM
