Lower Cover
Recently dodged some cinder blocks that fell off a truck at about 80mph. a small chunk took out the lower cover that sits below the radiator. Does anyone know a source for body parts?
I'm guessing the you mean the plastic undertray, that is sort of triangle shaped on the ends with a narrow strip that connects then across the bottom if the core support.
The part can still be bought new and I got one from Gaudin in Las Vegas not that long ago. Part numbers do vary by year, so there are a couple of possibilities for a part number.
Used ones can be found as well, but they are prone to the sort of damage you describe.
Forum sponsor S N G Barratt list the Undertray for your 1997. Part Number HJE6484AB at $255.87
SNG Barratt - The Ultimate Jaguar Parts Specialist
Andrew Fanshawe
Apr 4, 2017 12:51 PM
