lowerings springs on xk8
Old Dec 9, 2012 | 02:14 PM
'00XK8's Avatar
Default lowerings springs on xk8
I have a 2000 xk8 with stock 18" wheels and 245/45 tires on front and 255/45 on the back. The lowering springs lower the car 1.5 inches. Has anyone used these springs without putting a lower profile tire on the car? I would hate to ruin my tires if they rub.
Old Dec 9, 2012 | 02:52 PM
XKRacer's Avatar
Don't lower 1.5 .... Just go the inch, then you will have no issues
Old Dec 9, 2012 | 05:28 PM
'00XK8's Avatar
I can only find springs that lower it 1.5 inches. Do you know of a brand that sells 1" springs?
Old Dec 9, 2012 | 05:54 PM
Paul Pavlik's Avatar
Mina Gallery provides Springs that lower the Car 1.25"
I installed the Mina Rear ONLY Springs. The Front was already low enough. Tires are 245-45/18 Front and 255-45/18 Rear. I am very pleased with the results:
Old Dec 9, 2012 | 07:08 PM
'00XK8's Avatar
Where can I find just the rear springs. I checked the mina website and only found all four springs together.
Old Dec 9, 2012 | 07:44 PM
mike66's Avatar
Paul, very sexy coupe........do you happen to have a before photo? I'm too lazy tonight to search the forum, did you replace any rear rubber, mounts, etc. in the process?
Old Dec 9, 2012 | 07:56 PM
Mina sold me the Rear Springs only for $250. Only other parts changed were replacing original Axle Shims with 7.5mm units to correct for camber change with new springs.
https://www.jaguarforums.com/forum/x...omplete-54377/
ym37tech
Feb 8, 2016 01:04 PM
08Z06
Oct 24, 2015 05:46 PM
1LowCat
Sep 14, 2015 07:51 PM
DustysSon
Sep 13, 2015 04:17 AM
Tar
Sep 6, 2015 11:24 AM
