Maintenance questions 05 XK8
Old May 5, 2017 | 06:26 PM
zidjan's Avatar
Default Maintenance questions 05 XK8
Hey folks my XK8 just hit 60K and I am currently doing a whole lot of maintenance to it:
I just did the Tranny fluid (Shop did this this to the tune of $900)
Spark Plugs ... I know it can last to 100K but the car is 12 years old now and never had plug change
Did the coolant/thermostat housing( it was leaking progressive worse since last year) I found a crack in the plastic
Did the belt, it was starting to make chirping noise..it's gone now.
Bled the brake fluids
Now for my questions:
1. When should I change the Power steering fluids? and how? is there a drain plug?
2. The headliner on the driver side is starting to sag, how do I fix this?
3. My third brake light went out, searched this forum and found a cheap option to fix it however the led light bar that was in forum is no longer for sale...anyone know a good substitute?
Other than that I've had the Jag for 2 years and it's been pretty awesome getting attentions in the gas station, parking lots and random persons...can't say the same for my friend's 2015 M3 ...LOL
Anyway thank's for the tips
Old May 5, 2017 | 06:58 PM
fmertz's Avatar
I think there are 2 ways to do it. The easy way and the right way.
The easy way involves getting the tank empty of the old fluid with a syringe, then refill with new fluid, run the engine for a bit and then repeat a couple of times. The old fluid gets diluted, and you repeat the process until you are convinced it is diluted enough. Folks do 1 liter of new fluid, I believe. This is the home garage solution.
The right way involves disconnecting the return line and direct it to a container for disposal. Then, there is apparently a special funnel to put on the tank that you fill up with new fluid. Then you run the engine. The old fluid gets dumped into the container, and the new fluid is properly supplied from the special funnel without making a mess. Then you eventually stop the engine and put the return line back on the tank. This is the way shops do it.
Good luck, keep us posted.
Old May 5, 2017 | 08:09 PM
StuG's Avatar
Here is a cheap fix for the hi-level brake light. I did this over a year ago and it is still working.
https://www.jaguarforums.com/forum/x...-light-159261/
Old May 6, 2017 | 01:38 PM
zidjan's Avatar
Woow....this is very helpful. I am going to do this :-)
The easy way seems like a better way to do it...thank you
