Message on Dash or Codes
Old Sep 30, 2018 | 11:01 AM
br549's Avatar
Default Message on Dash or Codes
HI, how is every One? I have a 2000 XK8 Convertible with 67888 miles on it. I keep Seeing a mess. or code of ASC Not Available and right after the mess.I see Trac not available mess. What do I look for, or can any one tell me where to look and what the messages mean? thanks for any Help BR549
Old Sep 30, 2018 | 11:15 AM
larueb's Avatar
read about cleaning the electrical plug ins on the throttle body. Clean both with electrical contact cleaner and reassemble. Should clear problem
Old Sep 30, 2018 | 11:23 AM
fmertz's Avatar
If you see these messages right a startup after the car has been sitting a while (overnight), it is a sign of an aging battery not able to maintain the required voltage during cranking.
Old Sep 30, 2018 | 11:49 AM
Jon89's Avatar
^^ What he said. These are some of the usual signs of a failing battery....
Old Sep 30, 2018 | 12:45 PM
rothwell's Avatar
^^ What they said about replacing battery - plus clean the wheel speed sensors. Plenty of info on here about how to do it.
Old Sep 30, 2018 | 09:57 PM
Johnken's Avatar
+1 on the sensors, especially if it happens while driving and resets each ignition cycle.
BTW do you see ASC not available or ABS not available? If I remember correctly dirty sensor always lights both. I can't imaging how you could have one not the other if its a common component like the wheel speed sensor.
ABS will stay after ignition cycle until you drive forward a very short distance at something like 15mph, then it clears until the dirty sensor causes same cycle.
John
jaguar0206
Dec 8, 2019 07:43 PM
SynySTR
Oct 17, 2014 09:33 AM
bassman64
Apr 20, 2014 04:25 PM
XTypeJagMan
Feb 28, 2014 08:38 AM
Jsedita74
Dec 12, 2011 05:57 PM
