Mileage loss after removing center muffler
Old Dec 5, 2013 | 09:29 PM
philhef's Avatar
Default Mileage loss after removing center muffler
I had my center muffler removed to give my car a deeper sound, which it did! But now it seems I'm getting less gas mileage. I thought it was supposed to work the other way?!?!?!
Old Dec 6, 2013 | 02:02 AM
XKRacer's Avatar
What happens is you enjoy the sound so much you keep putting your foot down
Old Dec 6, 2013 | 02:46 AM
DaveC's Avatar
OMG Phil!! Milage should be the last thing you should worry about. No one has ever asked me what my mileage is. Now on the other hand my commuter car is a 2012 Ford Focus that is running at 35.1 MPG.
Old Dec 6, 2013 | 11:08 AM
Rey's Avatar
Rey
Try "rebooting" your ECU, so the motor can "relearn". It is incredibly easy to do. Just remove the battery leads from the battery. Then connect the positive and negative leads together for five minutes - this will discharge some of the memory of the ECU; and it will relearn the motor next time you start the motor.
Rebooting should be done after every modification.
Old Dec 6, 2013 | 07:33 PM
philhef's Avatar
I'll give it a try!!
And I stopped driving my XF as much because she drinks like a ***** without a tab!! Lol.
And my XK 8 gets much better mileage!!!
Old Dec 7, 2013 | 01:53 AM
JagV8's Avatar
Has it reduced the back pressure? If it has then it'll reduce the EGR and thus lower mpg.
Old Dec 7, 2013 | 04:20 PM
scardini1's Avatar
"Has it reduced the back pressure? If it has then it'll reduce the EGR and thus lower mpg."
You have GOT to explain that to me.
Old Dec 8, 2013 | 06:58 AM
Norm 427's Avatar
"Seems" = you're not sure.
I'm betting that your mileage hasn't changed. The change in back pressure wouldn't be enough to change anything noticeably on these engines when the engine is being driven in the lower RPM part of the powerband as we do when we're driving normally in traffic, etc.
JMHO
FrickenJag
Jun 16, 2025 02:15 PM
Wolfy
Sep 11, 2015 06:27 AM
1964Daimler
Sep 9, 2015 11:28 AM
RedRider48
Sep 7, 2015 09:41 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
