misaligned chain and guide
Old Jun 27, 2023 | 07:17 PM
Orange Man's Avatar
Default misaligned chain and guide
have been working on my 99 xk8 convertible "project car" off and on for about a year. Bought a kit in order to replace tensioners, guides, chains, sprockets, etc. (It has 168,000 miles on it). While removing the old rails, one of the bolts broke. I ended up buying a "time-sert" kit to drill out the old bolt, re-drill the hole and insert the double threaded insert. When completed, the insert looked flush with the block. However, when as I was tightening the bolt to torque specifications, the bottom of the rail began to move toward the block, leaving a gap between the chain and rail. (see picture).
Suggestions have been.....1. use a wedge washer to make up the difference. 2. replace the head. 3. Re-drill hole with the next size bit and re-install a slightly larger "time sert". Any advice/ideas would be appreciated.
Old Jun 28, 2023 | 03:59 AM
Superchargedxkr's Avatar
As I said before, a wedge washer, you can even grind the washer to the as near perfect angle/thickness you require, torque it all up with a little thread lock on the stud for peace of mind and it should be fine .
Simple fast adjustable cheap, what's not to like?
Only downside, its not as the engine designers intended and also, it would have to be thin so as not to move the chain guide out too much at the fixing location whilst correcting the angle.
Old Jun 28, 2023 | 05:54 AM
xalty's Avatar
you’re using the wrong chain guides
put the right ones on then reassess the situation
Old Jun 28, 2023 | 06:32 AM
michaelh's Avatar
Unfortunately, many of the kits come with the wrong guides:- the ones you have fitted are for the later Morse primary chains. See this (long) thread from dan02xk8:
https://www.jaguarforums.com/forum/x...3/#post1513371
This post of BobRoy's contains the part #s for the correct ones:
https://www.jaguarforums.com/forum/x...6/#post2135756
Peter_of_Australia
May 2, 2023 10:15 AM
drmike
Sep 20, 2021 04:18 PM
Captain K
Jan 15, 2014 09:27 PM
mbs xk8
Sep 17, 2013 08:58 PM
kdross
Sep 9, 2010 08:08 AM
