Misfire
Old Oct 7, 2008 | 08:34 AM
Brutal's Avatar
Default RE: Misfire
with a hand held Jaguar code reader we can see on most models a misfire counter that shows if a coil is misfiring and how many times before it gets bad enough to turn on a check engine light. Coil break down is common and replace the one doing it, unless you have a v6 in a X or S type. Then if a coil is misfiring unter the intake manifold replaced all 3 coils as most of the labor is pulling up the intake not replacing the coils. Any time you close to a 100k replace the plug when doing a coil. And dont let it keep going as misfires are a big contributor to killing cats
aode06
Jul 28, 2023 02:26 PM
pnwrs2000
Nov 17, 2015 04:04 AM
Norri
19
Sep 28, 2015 08:43 AM
reb1999
Sep 26, 2015 08:41 AM
