Misfire solved P0300, P0303, P0307
Old Aug 27, 2025 | 09:41 AM
NGB's Avatar
NGB
Default Misfire solved P0300, P0303, P0307
Took my XKR into a garage due to bad running/misfire, they diagnosed it needed the supercharger rebuilding. It got sent for rebuild and the rebuilder told me it was fine but I had it done anyway as it was with them. Picked the car up when the garage had refitted it and it went wrong again on the way home. This was last year and I packed it away as I’d fallen out with it and already spent lots on various other bits.
Got the car out again to tackle this, fault codes P0303 cyl 3 misfire, P0307 cyl 7 misfire, P0300 random misfire. Pulled the plugs, they were oily in the wells so I replaced the plug seals and cam cover seal. Fault codes gone and runs fine. Why the garage didn’t pull the plugs for a misfire I don’t know but it seems the seals were letting by.
Old Aug 27, 2025 | 10:19 AM
Pistnbroke's Avatar
You could have just blown out around the plugs with compressed air to clear it
Old Aug 27, 2025 | 01:26 PM
michaelh's Avatar
Indeed. Leaky boss seals is a fairly common issue. A garage best avoided, IMO.
Old Aug 27, 2025 | 08:22 PM
cat_as_trophy's Avatar
+1 . . . I agree with Michael.
If you are reliant on a workshop to diagnose, check and fix oiled plugs, it's high time to look elsewhere for your go-to garage. Perhaps I sense you know this already because I sense your frustration. Don't know your location, but others here may help with local knowledge if you advise.
OTOH, you have pulled out the tools, done yourself what any competent shop should have done . . . and you have fixed the problem. Good work on replacing the cam cover seal as well as all plug seals.
Cheers,
Old Sep 1, 2025 | 07:43 PM
scottatl's Avatar
New plugs are so cheap, it is worth to check and see if that is the problem. For $60 bucks you either fix it or get more diagnostic information. Glad it worked.
KLinRaleigh
Apr 28, 2025 08:28 AM
calvinG
Nov 8, 2023 11:52 PM
asdf
Apr 11, 2023 10:18 AM
Darrol2004
Sep 2, 2022 09:23 AM
Jeffrey David Benson
Feb 9, 2022 11:31 AM
