Moving to Italy
Old Jan 26, 2026 | 10:47 AM
wombocombo's Avatar
Default Moving to Italy
Hi All,
Looking for some advice, I have a 2000 xkr and will be moving to Italy. I want to take my baby with me but I believe it needs some mods to make it compatible. Has anyone don’t this before?
Old Jan 26, 2026 | 12:11 PM
dibbit's Avatar
You'll need to convert the RHD headlights to LHD. You can buy replacement beam deflectors or you can cut the existing ones down as a mirror image. You access them the same way you get to the headlight bulbs, through the access panel in the wheel arch.
There are a few threads on this topic on the forum, eg:-
https://www.jaguarforums.com/forum/x...ersion-109771/
Old Feb 1, 2026 | 03:01 AM
Pistnbroke's Avatar
European cars dont have the beam kink style of dip but the square cut off . You will also find an arrow on the glass indicating the direction of dip. If the tester sees this you will fail . You could grind it off and pollish the glass
Old Feb 1, 2026 | 03:12 AM
dibbit's Avatar
For my UK car, I just cut the deflector down in the mirror image of what was originally there. Never had a problem passing the inspection here in Spain, and they will fail you for anything.
VinceCh
Sep 18, 2020 08:55 PM
peterg19
Apr 8, 2015 06:29 AM
Rick Padilla
Jan 12, 2015 05:25 PM
jman3566
Exterior
Oct 11, 2008 12:44 AM
