My brakes are urinating - with video!
Old Mar 15, 2019 | 06:28 PM
scottatl's Avatar
Default My brakes are urinating - with video!
Just changed my brakes. My guess is I broke the seal when I cleaned the caliper with a wire brush.
Has anyone rebuild the seals on the calipers or have you just purchased new calipers? Let me know your past experience.
File Type: mov
Old Mar 15, 2019 | 07:04 PM
Ltd's Avatar
Ltd
Default New caliper seal
Not hard to replace seals. Seals are cheap and available. Time spent though... Would be better to just get rebuilt calipers.
Old Mar 15, 2019 | 08:17 PM
DavidYau's Avatar
For my 1999 XK8, the whole caliper unit is USD700 each, whereas the seal kit is only approx. USD60. For this price difference, I would get the seals and give to my local mechanic to do the job as I don't have the tooling to dis/re-assemble and bench test. I would be concerned as brakes are essential safety items.
Old Mar 16, 2019 | 02:40 AM
flatsix's Avatar
Hi,
thats weird, are you shure that the hose fitting is tightend up? It is definitly not possible to damage the seal with a wire brush. the seal is inside the piston bore and you can't get there with your brush. Its only possible to damage the dust cap, but if so it would not cause leaking.
Fritz
Old Mar 16, 2019 | 06:57 AM
That looks to be coming from the hose to caliper connection ........?
Old Mar 16, 2019 | 07:40 PM
scottatl's Avatar
Originally Posted by flatsix
Hi,
thats weird, are you sure that the hose fitting is tightened up? It is definitely not possible to damage the seal with a wire brush. the seal is inside the piston bore and you can't get there with your brush. Its only possible to damage the dust cap, but if so it would not cause leaking.
Fritz
I think you are correct, I reused the crush washer and upon inspection it is bad.
mikchek
May 8, 2019 11:38 AM
malx
Nov 27, 2015 06:27 AM
mustangtyson
Jun 27, 2015 03:18 PM
alabbasi
Nov 21, 2013 10:40 PM
jimlombardi
Nov 6, 2012 11:30 AM
