My Dream car is giving me nightmares....(XKR 100, Houston, TX)
I have a 2002 XKR 100, that is now in restricted performance. The car was running great, then started to misfire a little and had a ruff idle. Now that the car is home, when I start it, seems to idle ok, but the engine light is on (restricted performance also). I plugged in my handy code reader and this is what I got:
P0117
P1638
P1642
P1797
P0117
Any suggestions on what to do, or any recommendations where to take it in Houston, Texas (North/Humble). I have heard good things about Momentum, but I have also heard they are very expensive, and the opposite side of town.
P0117
P1638
P1642
P1797
P0117
Check a few simple things first that could play havoc with your electrical system.
- Are the battery connections clean and tight.
- Is there water under the carpetted floor of the trunk?
- Is the battery main ground cable to the chassis clean and tight?
- Is the spare tire loose in the wheel well...make sure it is not bumping into the big fuses on the right rear wall of the trunk under the carpet
- Perform a 'hard reset' of the computers in the car by disconnecting the negative battery cable, and touching it to the positve battery terminal for a few seconds.
- Have the battery load tested at an auto parts store.
Let us know how it goes...and start posting in the Xk8 and XKR forum section, where you will find a larger group of helpful people. There are a number of guys from your area in that forum. Also..don't multi-post or you will upset the moderators.
FS[NorthEast]: Jaguar XKR Wheels for Sale
Griffbritgreen
Jul 27, 2016 05:43 AM
