My new black headliner for 45.00.
Old Aug 18, 2013 | 07:07 PM
  #41
xenophobe's Avatar
Thanks for the tips! Even though I paid close attention to everything you said in this thread, every bit helps. I'll be doing it outside, and I have hepa masks, though they don't really help with fumes, it does help with the particulate matter floating about.
I'm going to be spraying the pillars and the visors as well.
I would try to Rit-Dye all the grey plastics, but I'm fairly certain they probably wouldn't take.
Old Aug 18, 2013 | 07:36 PM
  #42
philhef's Avatar
I used same paint on visors and light cluster. Works great.
Old Aug 19, 2013 | 07:17 AM
  #43
xenophobe's Avatar
Any chance you can take some better pictures with a camera? I admit, I'm a bit concerned with actually doing it, cause once you do it, you can't really go back. I'd like to see a picture of what the top looks like completely down, how you say it looks crumpled or out of the ordinary if possible. I'm still gonna do it, but I'd like to see better pictures if possible. If not, no worries.
Old Aug 19, 2013 | 07:54 AM
  #44
philhef's Avatar
Here's a pic down. It's raining here today so I'll add a few more when it stops.
The flash makes it look a bit mottled but its solid black. It looks like the more I use it it gets softer.
Old Aug 19, 2013 | 08:32 AM
  #45
philhef's Avatar
Old Aug 19, 2013 | 08:34 AM
  #46
philhef's Avatar
iPad flips pics. Sorry.
Old Aug 19, 2013 | 09:50 AM
  #47
JagTheRipper's Avatar
Looks really nice. Goes well with the color combo! Good job!
Old Aug 19, 2013 | 09:59 AM
  #48
WhiteXKR's Avatar
Originally Posted by philhef
Attachment 51538
It really looks great.
Consider trying the spray also on the faded seatbelts that almost every black XK8 has.
Old Aug 19, 2013 | 08:06 PM
  #49
philhef's Avatar
Black on black on black on black on black! Lol
I think that's why I want the suede in the seats and door inserts. Needs texture. A friend has an amazing Porsche Boxster S with a black leather interior and red piping and stitching details in the seats. It's soooo hot! If I could figure out how to do something to give a touch of color to my interior, I would. I've actually thought about using the red as well since I've got the red badges and caliper covers.
All ideas swimming around in my head. I may make a mock up and stick to door just to get a feel before I make any real commitment. Doors I can do myself, seats, not so much!!
Any custom interior pics out there??
Also found a carbon fiber vinyl that looks interesting as well. Again, just thinking.
Old Aug 21, 2013 | 07:07 PM
  #50
philhef's Avatar
Just finished suede door inserts and speaker covers.
Old Sep 5, 2013 | 01:51 AM
  #51
xenophobe's Avatar
So far I only managed to do the pilliars and the front top piece. Haven't done the headliner yet. So far, 1.5 cans. I'll probably need a 5th can to finish the headliner, but we'll see. That should get done tomorrow.
Overall I'm pleased with the results of the paint on cloth, but on plastic it doesn't seem to bond so well. I've set some parts to cure overnight, hopefully the plastic bits that I've painted will be sufficient.
Old Sep 5, 2013 | 04:40 AM
  #52
philhef's Avatar
Yeah, it eats up the paint but worth it. (At least to get a good black.)
I've really been using the convertible top and its really holding up well. I actually usually much more now that I'm embarrassed to leave the top cover off. And the fabric is stiffer so it doesn't flap in the wind.
I also just sprayed my old mats to use on long rainy spells and they even look brand new. This paint is the bomb.
Old Sep 5, 2013 | 03:17 PM
  #53
xenophobe's Avatar
Yeah, on cloth, that paint works great. Getting it nice and even black all across wasn't an issue like I thought it might be... you do need to make sure and get proper coverage. And my foam cloth still feels nice and rebounds well. I'm absolutely certain the headliner will come out just fine as well!
Old Sep 5, 2013 | 04:46 PM
  #54
philhef's Avatar
I'm on the verge of doing my XF door cards as well. I want the interior blacker. I tried it on a spare trim piece to see how it holds up and it's almost impossible to damage it. I need to see if they have a soft black.
Old Sep 15, 2013 | 01:50 PM
  #55
scardini1's Avatar
Default Painting The Visors
First: Mucho Thanks to Philhef for giving me the nudge to do this.
Changing the visors from gray to tan has taken a fair amount of paint - more than one can. After a few coats, I noticed that the surface of the visors was becoming very rough. Tufts of cloth were sticking up and hardening. From a tactile standpoint, it was unacceptable. You can see these bumps clearly in the pic.
BTW: the paint was wet when I took the first pic - the wrinkles on the label flattened completely when the pain dried. It looks a little strange because the color differs from the surrounding cloth, but I hate visor labels (except the "women should remove constricting clothing" of course - lol), so it doesn't bother me too much.
Remember to save enough paint for one last coat with the mirror flaps closed. There will be an unpainted line just along the previously rotated edge.
I tried various methods to smooth and soften the surface. What finally worked well was a very fine Scotch-Brite cloth. To be honest, the cloth was already worn a bit from occasional kitchen use; I can't say for sure that a new, unworn cloth would be as effective. I believe that scrubbing the surface smooth after every one or two coats throughout the process will definitely improve the project. It may also apply to other cloth-painting projects.
As Always: GOOD LUCK TO US ALL!
Old Sep 15, 2013 | 02:01 PM
  #56
philhef's Avatar
Mentioned pics but none on post. Like to see.
I had a bit of the rough look but I didn't mind. It's much better than the really stained headliner I had!
And an update on wear. Since I've had the remote top, I use it every day. The finish has held up perfectly. Ad I don't have to use the top cover now. Looks great all black!
Old Sep 15, 2013 | 02:29 PM
  #57
scardini1's Avatar
Default Bumpy Visor Pic
Hi Phil,
See if this works. For some reason the last attempt must have bombed.
The second pic is the Black on Black on Black (on Black) you asked for. Enjoy.
Attached Thumbnails My new black headliner for 45.00.-img_20130904_192823889_hdr-copy.jpg   My new black headliner for 45.00.-cimg0113.jpg
Old Sep 15, 2013 | 02:45 PM
  #58
philhef's Avatar
Hi Phil,
How does the tan match? I know they look better in person too! I can't get a single photo of mine to look as good as in person!
Old Sep 15, 2013 | 06:53 PM
  #59
xenophobe's Avatar
Hi Phil,
Mine came out much smoother. I put on many light coats... it looks like you might have put it on too heavy?
The airbag decals looked like that on mine when they were wet with paint... as soon as they dried, they dried nice and flat.
I still haven't done the headliner, but I'm all prepared... I dug through my storage locker and found my paint mask and I have a little more than 2 cans left and all the plastic sheeting I'll need. I was just waiting for the ambient temps to drop below 80 so I wouldn't melt inside....
I have the front pilliars, the top and all the plastic bits done already. Another XK owner saw me when I was at the auto parts store and he seemed pretty impressed. The black makes it look so much more modern and new.
I'm disappointed that the factory didn't realize they were doing the verts a disservice by doing grey interior. Black just makes the car look so much newer and much more expensive. I'll post pictures when I'm done.
Old Sep 15, 2013 | 08:11 PM
  #60
philhef's Avatar
Mine too, actually look a bit like suede. I think the black may hide a lot of flaws. My bother's tan mustang looked more like these tan visors. It takes a lot to cover the lighter colors I guess.
