My xk8 start and then cut
Old Feb 17, 2022 | 04:55 AM
Lukexk8's Avatar
Default My xk8 start and then cut
Hi guys my xk8 1997 4L start and cut !!!
i already changed ignition coil, fuel filter, plugs, crank sensor.
any body have an idea ?
thank you so much for your help
Old Feb 17, 2022 | 05:02 AM
Lukexk8's Avatar
Default Start and cut !!! Poor vehicle performance
Start and cut
Old Feb 17, 2022 | 06:02 AM
Jon89's Avatar
Could be a failing fuel pump. Very common in the 4.0 cars, particularly when they sit for long periods of time....
Old Feb 17, 2022 | 06:30 AM
JayJagJay's Avatar
Are there any codes present?
Can you please describe a little better what is happening, how it stalls, will it start right back up and stall again? Starts, runs rough until it stalls? Tries to keep running?
Try unplugging the MAF sensor. It's right after the air filter box, and try to start again... What happens?
Old Feb 17, 2022 | 09:17 AM
Lukexk8's Avatar
Thanks for your answer… I try the maf sensor to disconnected it and back but it’s still the same when i start the car it run for 2 sec and stop every time!!!
Old Feb 17, 2022 | 09:32 AM
JayJagJay's Avatar
Disconnect and leave disconnected - don't reconnect - and try to start. 2 or 3 times, disconnected...only.
Old Feb 17, 2022 | 09:55 AM
michaelh's Avatar
Do you have fuel pressure at the schrader valve on the fuel rail?
This post from Johnken shows where it is under the engine cover:
https://www.jaguarforums.com/forum/x...1/#post2204864
If you turn the ignition on for a couple of seconds, and then off again, you should see a good spurt of fuel if you depress the valve. Make sure you have some rag around to catch any spray.
If that checks out OK, then you need to get a code reader. A cheap ELM327 will do fine for reporting basic OBD codes.
Smokey59
Nov 27, 2022 12:02 AM
euphonium01
Mar 30, 2018 05:05 PM
Jdogsofla
Jan 13, 2017 10:38 PM
David7
Apr 25, 2015 08:55 PM
HouseCallAuto
XJ40 ( XJ81 )
Jun 27, 2011 11:07 AM
