Mysterious Coolant overflow
My lovely 2002 convertible is pumping out all its coolant on every journey. It is over filling the overflow bottle in the inner wing. I suspected the heater core because all the obvious hoses and expansion tank look OK. I short circuited the flow to the heater core with a short pipe from ebay to cut out the heater core, but no improvement. I suspect it may be the small electric motor on the fire wall under the coolant flow control. Does anyone have any experience on this?
Try using a coolant pressure tester. If the coolant is overflowing it may be expanding excessively because it is not being held under pressure.
It also could be a the fill tank cap not holding pressure.
And BTW, do not take any more journeys until this is solved...you run a serious risk of major overheating engine damage.
Never run with a cooling issue. Overheating is an engine killer on these cars.
The Atmospheric Recovery Bottle in the wing has a large capacity. If it is overfilling, you have very little coolant left circulating the engine.
There has been a recent thread on the Heater Motor Pump. It's in the HOW TO at the top of the threads:
https://www.jaguarforums.com/forum/x...41/#post752880
X308XJR
May 20, 2019 06:50 PM
