Mysterious fan sound.
Old Jun 9, 2014 | 04:05 AM
zecretw's Avatar
Question Mysterious fan sound.
Hi experts!
In my 2002XKR I have lots of electrical things to fix and that is not realy a problem. The other day I stripped out some lojack system that just went on beeping. Some nice hardware though, with satelite tracking and a SIM card. Probably outdated and useless 'caus I cant find any info on it on the net.
The thing I want to ask you is that when I turn the key to the second stage, "drive mode" with the Engine off I can hear a fan start running on the passenger side. (stearingwheel is on the left). When I switch the key off, it runs a few seconds then the fan is turned off.
Before ripping the right half of the car apart, does anyone know what this fan is for, should it be there or is it something someone has put in there?
This care has gone thru Three countries and a lot of owners.
Ofcourse I have turned off the climate control system using the knob.
Any suggestions welcome.
Old Jun 9, 2014 | 05:26 AM
RJ237's Avatar
There is a cooling fan under the ECM, but I don't recall it running after the ignition is off.
Old Jun 9, 2014 | 07:37 AM
The Coupe's Avatar
RJ237 is right...you're hearing the cooling fan for the ECM.
Old Jun 9, 2014 | 08:40 AM
Mountaincat's Avatar
That sound is probably your intercooler coolant pump running. Get a flashlight (torch) and look under the air filter box and you'll see the pump.
Old Jun 9, 2014 | 09:21 AM
RJ237's Avatar
I wasn't sure if there was an electric pump for the intercooler, not being familiar with the XKR, but that sounds like the right answer.
Old Jun 9, 2014 | 04:52 PM
Jdub's Avatar
ud
I remember when I popped open my box and saw the fan in there. I thought that was pretty smart. Especially considering how hot it can get under the hood.
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
LnrB
Oct 13, 2015 12:45 AM
workworkwork
Oct 1, 2015 01:44 AM
Darrenmb
Sep 27, 2015 08:43 AM
