Need 4.2 XKR Belt Diagrams
Old 07-20-2018, 09:26 PM
giandanielxk8's Avatar
Received 1,355 Likes on 729 Posts
Default Need 4.2 XKR Belt Diagrams
Today I was finally getting around to changing the supercharger and serpentine belts and pulleys. I drained the radiator, removed the fan assembly and radiator hoses. Then I hit a snag, 2 to be precise.
The first, I never took note on how the serpentine belt or the supercharger belt were routed. Now I can't make heads or tails of it. I would appreciate it if someone could please provide me with the belt routing diagrams for both.
The second hiccup was that, I am unable to remove the intercooler cap using the tool suggested in previous threads. You know, the one were you use a bolt and two nuts to fashion a giant makeshift allen key that requires a 19 mm wrench to turn. Problem is, the damn cap seems to have forged itself onto the intercooler of the supercharger. I can't muster enough strength. I have tried both righty tighty and lefty loosey and nothing.
Will the supercharger intercooler fill itself as I add coolant to the expansion tank once the thermostat opens up at optimal operating temperature or is it required that I add coolant via the supercharger's cap?
Old 07-20-2018, 11:08 PM
rothwell's Avatar
Received 1,252 Likes on 687 Posts
Belt routing page 136
VSB_07_2004.pdf
The following 2 users liked this post by rothwell:
giandanielxk8 (07-21-2018), Johnken (07-21-2018)
Old 07-21-2018, 02:49 AM
GGG is offline
Received 16,820 Likes on 12,177 Posts
From JTIS:
Old 07-21-2018, 09:28 AM
Got it routed according to these diagrams but I can't do it. The tensioner requires a herculean amount of energy for me to be able to move it when trying to pull on the belt. Is that normally done with some tool? On the XK8, I remember you could move the tensioner with a torque wrench or a ratchet wrench with a cheater bar, but I see no way of doing the same thing on the XKR.
Is there a way of releasing tension on the tensioner so I can finally get this damn belt on?
Old 07-21-2018, 11:33 AM
Update, I figured it out and got it done. Problem solved. I noticed that both tensioners have a square slot to which a ratchet without socket on fits. Used an extension bar to clear some space with the ratchet and was able to move the tensioner that way. It was still hard, but I didn't require Herculean strength.
Does anyone know if the supercharger intercooler will be filled if I only fill through the expansion tank? I am unable to remove the cap on the intercooler.
Old 07-21-2018, 12:20 PM
Today everything seems to be working out. Found a better spanner that was long enough to provide significant torque and got the cap off.
Old 07-21-2018, 02:56 PM
Jon89's Avatar
Received 4,291 Likes on 2,818 Posts
Yep, inserting a breaker bar with a 3/8-inch end on it into that square hole on the front face of the tensioner arm allows you to get the leverage you need to move the arm and remove / replace the belt. My buddy and I just did that today on my wife's 2006 XK8....
Ragn0r
04-18-2016 05:49 AM
Jlolsen
11-14-2015 07:38 AM
XKR2000
09-05-2014 07:57 PM
Bacardi 151
06-01-2012 03:16 PM
2000blackxkr
09-13-2009 10:28 PM
Quick Reply: Need 4.2 XKR Belt Diagrams
