need help to id hose
Old Aug 8, 2015 | 04:31 PM
jeremys's Avatar
Default need help to id hose
Hello all
2 weeks ago replaced leaky expansion tank all was well, however now I have noticed a leak, maybe coolant?, coming from a large connecter about 12" below the throttle body assy on passenger side of middle, that attaches to a metal connector that looks like it goes to the transmission , Is this a cooling line looks like just a bad clamp? but since going to trans not sure.
Any info on this hose would be welcome, maybe now that expansion tank is not leaking extra pressure has moved leak to another soft spot
Old Aug 8, 2015 | 04:57 PM
test point's Avatar
Sounds like the Norma connector from the metal tube from the coolant pump area to the 'octopus' heater system hose between the throttle body and the fire wall. Famous for leaking. The solution is to replace a simple, common 'O' ring within the connector. Unfortunately, getting to the O ring is a problem.
How to here: https://www.jaguarforums.com/forum/x...e-seal-119434/
Old Aug 8, 2015 | 05:42 PM
jeremys's Avatar
thanks test point read link and understand here I go again
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
mikiep
Dec 20, 2019 07:37 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
