need info on connector near fan shroud
Old Dec 22, 2016 | 05:49 AM
Julian Black's Avatar
Default need info on connector near fan shroud
4.2 engine. On US drivers side (left), sitting loose near top of fan shroud is a large wiring connector, next to it, with wires feeding off same loom is an little 2 wire connector. What is this little connector for? I need to test, as wiring is pretty brittle and breaking now to it.
Thanx bunches
Old Dec 22, 2016 | 07:14 AM
Old Dec 23, 2016 | 11:00 AM
RaceDiagnostics's Avatar
The larger connector is Vbat and ground, the smaller one is Vbat and an on/off signal from the engine control module.
Connector LF35-1 colour code W, on/off signal, may be serial digital, analog or PWM?
Connector LF35-2 colour code WU, Vbat.
