Need wider rims & tires for xk8
Old Jul 23, 2015 | 02:29 PM
2stick's Avatar
Default Need wider rims & tires for xk8
i have a 98 xk8 going w/ new rims & tires
My question is what is the widest tire I could put on the rear
And the widest for the front . I read on this form a guy fit 285/40/18 w/ no probably but never said what year his car was or what size he put on the front or if he changed to a different offset for either front or rear wheel.
Any info will be highly appreciated
Thanks Jeff
Old Jul 24, 2015 | 08:07 AM
ccfulton's Avatar
The optional 20" wheels have a 285 rear and 255 front tire on 10 and 9" wheels respectively. Offsets are 18mm rear, 25mm front.
All year cars are the same so that setup will work well on a 98.
You can get away with slightly wider wheels and tires but you have to be careful with offsets to avoid rubbing.
Old Jul 24, 2015 | 10:05 AM
Jandreu's Avatar
Might not be as wide as you want but I have 255/45/18 with 24 offset front and rear, plenty of room left in the wheel wells for wider. As said watch the off set.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Here's a great comparison calculator. While not vehicle specific it does show you what to look for.
Old Jul 24, 2015 | 11:05 AM
2stick's Avatar
Thanks ccfulton
i have to drive a few miles on a gravel road just to get to the blacktop when I leave are home cattle ranch would I have problems w/ if I went w/ a 20" wheels being the side walls are that much shorter
I only drive this car for fun
Old Jul 24, 2015 | 11:11 AM
2stick's Avatar
Thanks. Jandreu
Going w/ 255 up front and 285 in back , just have to figure out what size rim I want now
2010 Kyanite XFR
Feb 16, 2016 11:40 AM
MrWest
Dec 1, 2015 09:18 PM
lickahotskillet
Oct 18, 2015 09:51 AM
Matei Dima
Oct 8, 2015 11:45 AM
lickahotskillet
Sep 11, 2015 07:54 PM
