New To Jaguar
Old Jan 14, 2016 | 04:12 PM
64vette's Avatar
Originally Posted by jimbov8
There is your problem, your car is not going to sleep because it thinks the key is still in there. You will need to get the flap moving and then lubricate it with some graphite grease. Hopefully that should solve your problem.
Are you referring to a very small metal "flap" inside the key hole itself (that the key pushes out of the way on insertion) ?
Old Jan 14, 2016 | 04:13 PM
jimbov8's Avatar
That is correct.
Old Jan 15, 2016 | 06:50 PM
KayScotts's Avatar
Just a quick update. I fixed the flap in the ignition canister to move freely by spraying in some graphite grease, thank you so much for tellin me to check that out because I never would have guess. I charged up my battery and the car fired right up. Tomorrow I'm going to use a volt reader on the battery with the engine off to confirm that that was the only reason the battery was being drained. Again thank you to all who have helped me so far along the way, much appreiciated!
Old Jan 16, 2016 | 02:52 AM
jimbov8's Avatar
Thanks for the update, hopefully you will now be okay.
tat2ist
27
May 20, 2022 09:41 AM
Jennifer S Flavell
Mar 18, 2016 07:42 AM
kulddy
Dec 31, 2015 12:25 AM
QwikCat
XE ( X760 )
17
Dec 26, 2015 08:40 PM
DaveInVA
Dec 21, 2015 09:54 AM
