new problems with 1998 xk8 help!!
Old Oct 2, 2013 | 06:05 PM
Shanice1's Avatar
Default new problems with 1998 xk8 help!!
Hello..and thx to all im new
i purchased a jag xk8 1998.... A few days ago i was on the freeway when i had to pull of because i realized the oil gage was completely down. I immediately got the car towed home.once home i turned on right away...after i checked the oil and there was still oil inside.i took off the oil tube and it was clogged did not replace oil pump..replaced spark plugs did oil change...after words the car has horrible knocking sound barely wants to stay on..please help..*on day of freeway incident all of the antifreeze came out
Old Oct 2, 2013 | 06:31 PM
RJ237's Avatar
Welcome to the forum and sorry to read about your problems. The knocking sound after losing oil pressure makes me think you have a failed bearing. But where did the antifreeze exit the system? Was it a hose or something else?
It would help to know where you are located, as one of the members may be able to assist.
Old Oct 2, 2013 | 06:33 PM
The oil pressure dropping to zero could just be a faulty sender unit but the knocking sound and barely running sounds a lot more serious.
The early V8 engines are well known for breaking plastic timing chain tensioners and fr timing chains jumping a tooth. At the very least, the camshaft covers need to come off to check the tensioners before you think of running it again.
Old Oct 2, 2013 | 06:58 PM
Shanice1's Avatar
thanks for replying I am in California..and no id didt see any leaks in the hose..The knocking noise really didnt become loud until after i put on new spark plugs and cleaned the oil pump pickup screen.When i pulled to the side of the freeway there was no sign of overheating the gauge was perfectly fine..when i checked the oil there was still some oil in there..
Old Oct 2, 2013 | 07:03 PM
Shanice1's Avatar
i haven't driven the car since iv turned on quickly to see if the knocking would continue.I saw some information on how the oil pump can have something to do with knocking.But i kind of want to rule out more serious issues like needing a new engine.Any suggestions.No lights or messages appear..no check engine light oil gauge is fine..just knocking noise that has only been noticed today.yesterday after car was told home i started the car and it sounded fine.
Old Oct 2, 2013 | 07:12 PM
WhiteXKR's Avatar
If all of the antfrreeze came out, and you continued to run the car for a few minutes it would likely be overheated and seriously damaged.
This can be assessed with a compression test on each cylinder.
Unfortunately this can happen without an overheat warning because the temperature sensor is not immersed in antifreeze liquid when ALL OR MOST of the coolant drains out. You should, however have had a low coolant warning.
Old Oct 2, 2013 | 07:17 PM
Originally Posted by Shanice1
..........When i pulled to the side of the freeway there was no sign of overheating the gauge was perfectly fine..when i checked the oil there was still some oil in there..
The temperature gauge is absolutely useless - it won't move from the centre position until the engine is seriously overheated.
1. you lost coolant so was there a burst or disconnected hose?
2. 'some oil in there' - any signs of a leak?
Old Oct 2, 2013 | 07:41 PM
Shanice1's Avatar
there was also no coolant warning..only thing i saw was the low oil gauge.how much does a compression test usually cost?
Old Oct 2, 2013 | 07:46 PM
Shanice1's Avatar
as far as the leak no..i havent spotted a leak..Im assuming there was a burst. I feel so overwhelmed.Hoping i wont need a new engine
Old Oct 2, 2013 | 07:48 PM
So does it have coolant now?
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Rlover
Mar 30, 2016 10:04 PM
arnoldmilk
Sep 3, 2015 07:42 PM
