No Start/ Sport mode button?
Old Jun 9, 2013 | 11:42 PM
plums's Avatar
Once it has charged, hook it up, leave trunk open for 15 minute. Measure voltage across the terminals and report the reading to two decimal points. Also, the brand and model of battery.
Old Jun 10, 2013 | 12:18 PM
Bob OB's Avatar
Default Battery test
Before charging; 12.40v. After charging 12.40v. At idle 12.60v. battery info;Autocraft Gold, part # 49H8 ,cranking amps 950, cold cranking amps 760, reserve cap. 160. Dated 5/11. I'm not seeing anything that would point to the battery. i'll be driving it every day for this week, and as I previously said it will start in neutral when it does this. Your thoughts? Thanks.
Old Jun 10, 2013 | 06:13 PM
Gus's Avatar
Gus
I would always start in “P” and when It does not start then try it in “N”. The theory is if it does not in “P” and it does in “N” then you should look at the adjustment then replacement..
Link http://www.jagrepair.com/images/TSB/307-01-1.pdf
FtypeRRR
Sep 26, 2015 05:46 PM
Jagged-X
Sep 24, 2015 05:08 PM
Steve10
Sep 20, 2015 12:27 PM
reb1999
Sep 19, 2015 07:30 AM
