is this noise big end and crank bearings?
Old Aug 14, 2016 | 08:18 PM
dan02xk8's Avatar
Default is this noise big end and crank bearings?
this video sounds ridentical to mine.,
i stopped at a traffic light the oil pressure went to zero the it went back up i got home changed the timing chain and timing chain tensioners and the noise is there.
there saying big end crank bearings??
Old Aug 15, 2016 | 02:30 AM
It would be better to post a clip of your own.
On this one the belt / pump bearing / alternator bearing squeal is masking the important sound but it does have the typical thump of big end bearing failure.
Not something to be ignored or postponed. It's a very short step from worn bearing shells to failure and a wrecked crankshaft.
richard1159
Apr 16, 2016 07:54 AM
TexMurphy
Apr 4, 2016 06:40 PM
byjosh
Apr 1, 2016 02:11 PM
Apr 2, 2007 11:08 PM
