Non OEM valve cover gasket
Old Dec 11, 2018 | 02:53 PM
larueb's Avatar
Default Non OEM valve cover gasket
Guys,
My valve cover gaskets are leaking again and I am looking for a very good non OEM replacement. I used the ones for the Lincoln LS v-8 one time and they were better than the paper thin ones that Jaguar offers.
Is anyone aware of quality non oem gaskets so I don't have to do this task every 18 months? I do wish fellpro or someone made a substitue.
Thanks!
Old Dec 11, 2018 | 04:10 PM
Gus's Avatar
Gus
Is this what you are looking for?
Link https://www.motorcarsltd.com/jaguar-...er-gasket-kit/
Old Dec 22, 2018 | 07:25 PM
Cabel's Avatar
Use the Lincoln LS rubber ones but make sure you install them with all mating surfaces and the gaskets themselves DRY per the Fel-Pro instructions.
Old Dec 23, 2018 | 10:55 AM
pdupler's Avatar
Another thing that affects the reliability of the seal is the thickness and density of the 28 little rubber isolators under each bolt head. The gasket may have been fine, but the isolators weak. I had to redo valve cover gaskets once after only a short while and found that the isolators that came with the first kit were a hair thinner, much softer and more pliable than the ones that I ordered the second time. I think the first set came from Christophers since it was done with the tensioners. I don't recall where the second set came from as its been too long ago. But its those isolators that provide all the clamping force since you can only turn the bolts in so far.
Vee
May 28, 2018 11:08 PM
David Bedoya
Jan 15, 2017 04:12 PM
polarisnavyxj
Jun 15, 2016 10:18 AM
steelels1
Oct 11, 2008 01:12 PM
slanteyedmonkey
Feb 5, 2008 08:50 PM
