Now THIS is leaving work in STYLE!
Old Aug 25, 2010 | 07:24 PM
Dave S's Avatar
Default Now THIS is leaving work in STYLE!
Well, finally happened today...hopped in the car and......
click!
Nothing!
Ouch! So, it's off to the local racing shop to work on it and figure out what happened. Just my luck it happened at work!
Dave
Old Aug 25, 2010 | 07:38 PM
Oops, hope you get it sorted all ok Dave....make sure to drop by and fill us in
Old Aug 25, 2010 | 08:04 PM
Brian2000XKR's Avatar
Good luck Dave. Hopefully, it will be something as easy as "jiggling" the Gear Shift knob and trying to start the car in Neutral. That intermittently faulty sensor has acted up about once a year for me.
Brian
Old Aug 26, 2010 | 10:07 AM
H20boy's Avatar
yup, same here! jiggle n try again soon after my battery went kaput.
Old Aug 26, 2010 | 11:22 AM
daddyo007's Avatar
Jiggle never worked for me. I had an had internal corrosion on the positive cable. But mine usually happened only when the car was hot. But with the temps this summer just sitting out side on pavement and being a black jag could have gotten it hot enough to cause this fault.
Just a thought from my end.
Old Aug 27, 2010 | 08:08 AM
Dave S's Avatar
Well, turns out that the battery had an internal short. Yep, two of the internal battery plates shorted out...wow...who would have ever thought up that????
Car is back and driveable, though the shop noticed that my back up lights and my side marker lights aren't working. He thought that it might just be bad bulbs, but they were working two months ago when I had my state inspection done. Hmmm...anyone know if they're controlled by the same fuse??
Dave
Old Aug 27, 2010 | 08:20 AM
user 2029223's Avatar
Banned
Glad to hear it turned out so well. Thanks for keeping us up dated and informed. So many of of our problem children are never heard from again.
Old Aug 27, 2010 | 08:43 AM
H20boy's Avatar
scratchin my head on the reverse lamps and markers.
Old Aug 27, 2010 | 08:58 AM
MarcB's Avatar
No, unfortunately they are separate fuses in the trunk. They are fuse #1 (Reversing) and #21 (Sidemarker/Tail) . The fuse/relay box in question is right next to the battery so perhaps something was "nudged" when they installed the new battery.
Or, more worrisome, perhaps the BPM suffered an issue from the low voltage? Fortunately I have had a lot of self inflicted voltage issues but never experienced a long term failure of any modules (knock on wood) Have you checked again?
Old Aug 27, 2010 | 07:09 PM
Danster's Avatar
I have always read in these forums that once the car starts acting "weird", it can usually be associated with a low voltage battery. These babies are sensitive I guess.
Old Aug 30, 2010 | 07:55 AM
Dave S's Avatar
I'll take a look-see at the fuse box in the trunk. That sounds reasonable.
Dumb question...what's the BPM?
Old Aug 30, 2010 | 08:33 AM
vagearhead's Avatar
The BPM is the Body Processor Module
Old Aug 31, 2010 | 07:58 PM
daddyo007's Avatar
..If you replace them with new do they only last a little while before blowing?
Do you have the extra ground on the tail lights yet? This is a fix for blowing bulbs if you do not have that second ground!
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
XJsc-guy
Sep 2, 2015 11:43 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
