O2 sensor/fuel trims
Old Sep 25, 2023 | 07:19 PM
2001XK8 Farmcar's Avatar
Default O2 sensor/fuel trims
My 2001 XK8 Convertible is my first Jaguar. As a teenager I did learn the art of masochistic auto ownership with a 1976 MGB (curse you Lucas Electrical). I had a set of tools in the trunk worth more than the car (not hard to do). I've owned this car for three weeks and have gotten my first code. A P1647 and a P1000. My research on this very helpful forum leads me to believe that it is a bank 2 O2 sensor fail. the fuel trim 3 and 4 are at -100.6% for long and short term at idle with coolant temp of 194 F, Question a) Does this mean it is running lean and should not be driven? b) Does anyone have a strong opinion that this is anything other than O2 sensor? Thanks in advance.
Old Sep 25, 2023 | 07:38 PM
RJ237's Avatar
A -100 is not plausible, so I would definitely replace the sensor. A negative fuel trim indicates the engine is running rich and the ECU is trying to correct it. Usually, when the LTFT reaches -25 the restricted performance message will be displayed.
Old Sep 26, 2023 | 04:46 AM
Thank you. I was unsure of how to interpret the negative value. Oddly the car is running fairly smooth, but gas mileage has dropped by 2 mpg. That seems to track with what you said. Wish me luck!
Old Sep 29, 2023 | 02:14 PM
JagV8's Avatar
Change the sensor (for the right part - no dodgy cheap ones!) and it should quickly relearn and be happy.
MattArnold
Apr 9, 2020 07:33 PM
PhilGR8
XF (X260)
Jun 29, 2017 12:28 PM
David SD
Jul 6, 2015 04:41 PM
gjcprintmaster
Jun 4, 2015 10:10 PM
SimonRage
Apr 21, 2010 08:23 AM
